Spinnor said:
Forgetting the elevator for a second, if we throw a ball at a moving wall the rebound velocity of the ball will depend on whether the wall is moving away from or towards the ball. Won't this same effect come into play with the elevator ceiling to some extent?
Bouncing off the ceiling is a whole separate issue, a problem complete in itself. I have had a look at it, to determine the speed at which the ball will bounce off the ceiling. (For this I assume the ceiling is a perfect solid body, and the collision is elastic.) A golf ball is a good choice for these experiments--it is designed for rough treatment and has surface pitting that minimizes air resistance.
To derive a general solution I'll first examine horizontal motion, for example, a golf ball bouncing off the front of an oncoming locomotive. Let their masses be m
1 and m
2, and their closing velocities v
1 and v
2. Considering both momentum and energy to be conserved, write the equations and solve them simultaneously. After a perfectly elastic collision--where no energy is lost--the ball rebounds with velocity
\color{Blue}{V{_{1}}^{'}\;=\;\frac{2\,V_2+(1-m)V_1}{m+1}}\;\;\small {where\;\;\;mass\;\;ratio\;\;m=\frac{m_1}{m_2}}
so when m
2 is massive, the mass ratio
m tends to 0 and the expression simplifies to
V{_{1}}^{'} =\; 2\, V_2+V_1
What interesting things can these equations tell us? Let's consider the special case of equal masses colliding, i.e., where m=1. Applying the formula, we find that after the collision mass m
1 has a speed
unrelated to its pre-collision speed. Amazing! Have you ever witnessed this? Sure you have--those executive toys where a couple of shiny steel balls are suspended on thin nylon line and allowed to bounce back and forth hitting each other. When the moving one collides with the stationary one, the moving one stops dead and the other one bounces away. For equal masses colliding head-on, the speed of each is entirely determined by the speed of the other. In fact, they swap their speeds (meaning, they swap kinetic energies).
