A bouncing ball hits a blob of putty on the rebound upward
The discussion focuses on a physics problem involving a ball of mass 9p dropped from a height of 6.0 meters, which undergoes a perfectly elastic collision with the ground. The problem requires calculating the ball's speed before impact, the time until a clay blob of mass p collides with the ball, the height at which this collision occurs, and the speeds of both objects just before the collision. Key equations for vertical motion under gravity are essential for solving these questions.
  • Understanding of kinematic equations for vertical motion
  • Knowledge of elastic collision principles
  • Familiarity with gravitational acceleration (g = 9.81 m/s²)
  • Ability to perform basic algebraic manipulations
  • Review kinematic equations for free fall and rebound motion
  • Study the principles of elastic collisions in physics
  • Learn how to calculate time of flight and impact velocity
  • Explore problems involving multiple objects in motion under gravity
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of collision dynamics and motion equations.
Arsen1451
New user has been reminded to show their work on schoolwork questions
A ball of mass 9p is dropped from rest from a height H = 6.0 meters above the ground. It
undergoes a perfectly elastic collision (rebounds with the same speed in the opposite
direction) with the ground and rebounds. At the instant that the ball rebounds, a small
blob of class of mass p is released from rest from the original height H, directly above the
ball, which is ascending. Assume that g = 9.81 meters / second2
, that air resistance is
negligible, and that the collision process takes negligible time.
(a) Determine the speed of the ball immediately before it hits the ground.
(b) Determine the time after the release of the clay blob at which the collision takes
place.
(c) Determine the height above ground at which the collision takes place.
(d) Determine the speeds of the ball and the clay blob immediately before the collision.
I don't know
Please someone help me
Arsen1451 said:
Homework Statement:: A ball of mass 9p is dropped from rest from a height H = 6.0 meters above the ground. It
place.
Relevant Equations:: I don't know
Please check your Personal Messages (PMs). You are required to post the Relevant Equations and show your Attempt at the Solution before we can offer tutorial help here at the PF.
So start with the basics -- what is the equation for the vertical motion of the ball as a function of time? Since air resistance is negligible, only the force of gravity is determining the acceleration of the mass downwards until it hits the ground. Then, after it bounces, the force of gravity is the only thing decelerating the mass (until it hits the blob). Please show the equations for the velocity and position of the ball as a function of time on the way down and on the way up. We can go from there once you post that work. Thank you. :smile:
