A bullet is shot into a block of wood
The discussion centers on a physics problem involving a 2.3kg wood block and a 10g bullet that embeds into the block, causing a pendulum to swing to a 33-degree angle. Key equations include the conservation of angular momentum and energy, specifically using the formulas for angular momentum of a particle and rigid body. The goal is to calculate the initial speed of the bullet, with emphasis on determining the potential energy of the rod and the combined system at the maximum swing angle. Participants highlight the importance of specifying units and clarifying the problem's objectives for accurate calculations.
  • Understanding of angular momentum and energy conservation principles
  • Familiarity with rotational dynamics and moment of inertia calculations
  • Knowledge of potential energy calculations in pendulum systems
  • Ability to interpret physics problems with correct unit specifications
  • Learn about the conservation of angular momentum in inelastic collisions
  • Study the calculation of potential energy in pendulum systems at various angles
  • Explore moment of inertia calculations for composite bodies
  • Review the principles of rotational motion and angular velocity determination
Students preparing for physics exams, educators teaching mechanics, and anyone interested in understanding the dynamics of pendulum systems and collisions.
pdonovan
1. A 2.3kg wood block hangs from the bottom of a 1.0kg, 1.2m long rod. The block and rod form a pendulum that swings on a frictionless pivot at the top end of the rod. A 10g bullet is fired into the block, where it sticks, causing the pendulum to swing out to a 33degree angle.
Angular momentum of a particle = mvr^2
Angular momentum of a rigid body = Iw
Conservation of angular momentum: Li = Lf
Conservation of energy: Ei = Ef
I have 3 stages set up. 0, which is right before the bullet hits the wood. 1, when the bullet is embedded into the wood and hasn't traveled anywhere yet. 2, when the pendulum has fully swung out.
L0 = L1
(Mbullet)(Vbullet)(R^2) = (Ibullet)(Wbullet) + (Iwood)(Wwood)
(.0144)(Vbullet) = 3.3242w
E1 = E2
(.5)(Ibullet)(w^2) + (.5)(Iwood)(w^2) = (Mbullet)(g)(h) + (Mwood)(g)(h) + PErod
I think the main issue is that I don't know what the potential energy of the rod is, but there certainly may be other issues. I believe h = .194m.
Any help is greatly appreciated!
If anyone sees any minor errors in my calculations (or major!) please please help, I'm trying to figure this out before a test. Thank you.
Is there some reason why you don't specify the units of the quantities? What's a "1.0 , 1.2--long rod"? Is a "10 bullet" a 10 kilogram bullet? 10 pound? 10 ton? Is a 33 angle 33 degrees, or perhaps 33 grads, or 33 radians (lots of revolutions!)? Marks are lost when units are ignored.
Also, you didn't state what the goal of the question is. What's to be calculated?
Sorry for the lack of units, the question was copy pasted.
So, what is it that you're trying to calculate?
The initial speed of the bullet.
The angular momentum of a massive particle about a center is mvr, not mvr2.
You can calculate the PE of the rod+block+bullet by considering the elevation of the centers of mass of the rod and the block + bullet combination. (Figure out the Δh's when they're at the 33° position).
If you equate the PE with the mechanical energy (rotational in this case) when the rod+block+bullet is at its lowest point, you can determine the angular velocity there, and hence the angular momentum of the ensemble. The bullet must have supplied this angular momentum.
10K
