A few Electromagnetic questions
13 replies · 4K views · last reply
Plasma
A:
http://i12.photobucket.com/albums/a234/Xuxyz/battery.jpg"
(a) i. Using the information in the graph, determine the potential difference Vo across the resistor immediately after the switch is closed.
Vo = Io * R
I don't know how to find Io using the grap, because as you can see from my link, it doesn't intersect at a specific point.
B:
http://i12.photobucket.com/albums/a234/Xuxyz/04-08-2007015444PM.jpg"
I only need help on part f
I don't know.
None, sorry. I don't have a clue.
C:
http://i12.photobucket.com/albums/a234/Xuxyz/04-08-2007020007PM.jpg"
Only part D
EMF = vBD
I = vBD / R
I know this is a lot, but I would appreciate any and all help.
For number 1, it looks to me like the graph shows a current of about 9.5 A??
*For your second question, what is happening as the loop is moving away from the wire?*
It's actually slightly below 9.5 A
The Magnetic field strength is decreasing.
1. Okay, slightly less than 9.5 A. :rolleyes:
2. So if the field strength is decreasing, what about the flux?
But I need an actual number for the equation to work.
The flux would be decreasing, too?
1. You must use your eyeball.
2. Yes, the flux is decreasing, good. From this, can you tell me which direction is the induced current.
I don't need to know the direction of the current, I need to figure out what it's equal to.
Well, I thought you might want to learn what is happening.
What does a changing flux produce?
A changing flux induces an emf around the circuit. Find out the relationship between this emf and other physical quantities.
