A field that is an ordered field in two distinct ways
  • Thread starter Thread starter BrendanH
    Field
The discussion focuses on finding a field that can be ordered in two distinct ways, specifically the set F of numbers in the form r + s√2, where r and s are rational numbers. The first ordering is established through a subset P of F, which includes positive members of the real numbers. The second proposed ordering involves a subset B defined by the condition that r + s√2 belongs to B if and only if r - s√2 belongs to P. There is confusion regarding whether B could be empty, as the poster believes that the elements of B and P do not overlap. Ultimately, the discussion emphasizes that the existence of a second ordering does not depend on the cardinality of B, highlighting the uniqueness of this field's ordering properties.
BrendanH
Find a field that is an ordered field in two distinct ways.
The set F of all numbers of form r + s√2 , where r,s ε Q and the operations of addition and multiplication are those of the real number system ℝ of which F is a subset, is an ordered field in that there is a subset P of F such that addition and multiplication are closed in P, and x ε F →
exactly one of the following:
x ε P; x=0; -x ε P
This means that P is the set of all members of F that are positive members of ℝ, so P is the positive reals in F.
A second way in which F can be ordered is by way of the subset B, such that
r + s√2 ε B iff r - s√2 ε P .
This I find troublesome, as (I am under the impression) that this implies that B = ∅.
My reasoning for this is that numbers in B will end in the digits that r - s√2 will end in (which would be, e.g., of form 1 - √2), and these are different than the numbers that r + s√2 span (for instance, 1 + √2).
Is B=∅? Are there faults in my reasoning?
The deluge of responses has me chagrined!
It is irrelevant that B would be the null set, as the above demonstration is just supposed to exemplify that it CAN be ordered in another way, irrespective of its number of members. The rationals and reals can but be ordered in one way, so in particular this field is a special case.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
