How to Calculate Input Power for a Gear Train with Frictional Resistance?
  • Thread starter Thread starter PizzaWizza
    Design Gear Train
This discussion focuses on calculating the input power required for a gear train with frictional resistance. The setup includes four gears, with the driver gear rotating at 100 revs/min and the output gear at 400 revs/min, while overcoming a load of 200Nm. The calculation involves determining the speed of each gear based on the number of teeth, finding the output power using the formula 2π x revs/sec x torque, and accounting for frictional losses of 5Nm at each shaft. The final input power is derived by adding the output power to the total frictional power losses across all gears.
  • Understanding of gear ratios and rotational speed calculations
  • Familiarity with torque and power equations in mechanical systems
  • Knowledge of frictional resistance and its impact on power calculations
  • Ability to apply the formula T1ω1 = T2ω2 for gear interactions
  • Learn how to calculate gear ratios and their effects on speed and torque
  • Study the principles of power loss due to friction in mechanical systems
  • Explore advanced gear train configurations and their efficiency calculations
  • Investigate the use of simulation software for analyzing gear train performance
Mechanical engineers, students studying mechanical design, and anyone involved in the analysis and optimization of gear systems will benefit from this discussion.
PizzaWizza
Calculating the input power required for a drive gear in a train.
I have 4 gears, all in line. The driver shaft A rotates at 100 revs/min and the gear has a diameter of 40mm. 20 teeth with a module of 2mm
The output is to rotate at 400 revs/min and has a diameter of 160mm with 80 teeth and the same module of 2mm
The two idler gears are both 100mm each and have 50 teeth each
The output gear is working against a load of 200Nm
All shafts have a frictional resistance of 5Nm
I'm going to try work backwards from my output Torque to see if I can calculate the input.
How do I do this taking into account the frictional resistance.
If I call each gear A, B, C & D respectively with D being my output.
ωD x TD = 400x200 = 80000 W
I'm really not sure what I do to the power here to include the frictional resistance and work back over to calculate the power input required for each gear.
Find the speed of each gear first, from the number of teeth.
Then multiply output torque by output speed to find output power.
The input power is output power plus losses, so for each wheel, calculate the speed times frictional torque, to find the power lost. Then add together the four values of power lost and the output power. This will give the input power.
Apologies, I've got my driver & driven the wrong way around. So driver gear rotates at 100rpm/min and has 80T and diameter of 160mm. The driven output shaft has 20T and a diameter of 40mm
I can find the rotational speed of gear C working back from Gear D via T1ω1 = T2ω2 ∴ 20x400 = 50xω2 = 160rpm/min for gear C which in turn means gear B is the same speed. So where do I find the torque for Gear C. It needs to overcome 200Nm to turn the output, do I multiply 205Nm by the angular velocity to achieve the power requirement in Watts?
I have drawn the diagram from your new description. You can find the speed of the four wheels from just the number of teeth.
Next find the output power from 2 pi x revs/sec x torque.
Now find the frictional power lost at each shaft from 2 x pi x revs/sec x frictional torque.
Now add the four frictional powers to the output power. This gives the input power.
Thanks very much. Makes sense
  • · Replies 26 ·
22K
25K
