How Do You Calculate the Net Gravitational Force Between Objects?
  • Thread starter Thread starter chocolatelover
    Gravitational Net
To calculate the net gravitational force on a 41.0 kg object placed midway between a 145 kg and a 445 kg object separated by 0.420 m, the gravitational force equations need to be applied correctly. The initial calculations presented were incorrect, particularly regarding the distances from the 41.0 kg object to the other two masses. The correct approach involves determining the exact distances from the midpoint to each mass and applying the gravitational force formula accurately. For part b, a clear expression for the forces acting on the 41.0 kg object must be established to find the position where it experiences zero net force. Understanding the arrangement of the masses is crucial for solving both parts of the problem effectively.
chocolatelover
Hello everyone,
Could someone please help me with this problem?
A 145kg object and a 445kg object are separated by .420m.
a. Find the net gravitational force exerted by these objects on a 41.0kg object placed midway between them.
b. At what position can the 41.0kg object be placed so as to experience a net force of zero?
F=Gm1m2/r^2
(6.67X10^-11Nm^2/kg)(145kg)(41.0kg)/.420^2=-2.2X10^-6
(6.67X10^-11Nm^2/kg)(445kg)(4)/.420^2=6.7X10^-7
-2.2X10^-6+6.67X10^-7=2.87X10^-6
Thank you very much
If the 41.0 kg object is "placed midway between them", how far is it from the first two masses?
Other than that, looks like you have (a) pretty much.
Thank you very much
Could you please tell me if a. looks correct?
For part b., would you just take the first one plus the middle one plus the third one and set it equal to the total force and solve for the middle one?
Thank you
a is not quite correct. You have the right idea except that:
1. As I said before, if the 41.0 kg object is "placed midway between them", how far is it from the other two masses?
2. Why do you get a smaller force due to the larger 445 kg mass? Larger masses should exert larger forces. Something is wrong here.
For b, you'll need to write out an expression for the force on the 41 kg mass.
Thank you very much
For part a., would I just take 4.7 X 10^-6 and divide it by 2?
Thank you
I don't see where "4.7 X 10^-6" comes in, so I'll have to say no, that is not what to do.
For the 3rd time:
If the 41.0 kg object is "placed midway between them", how far is it from the other two masses?
It's in the middle. Is that what you mean? So, wouldn't you just take
6.67 X 10^-11(145)(41/2)/.42^2?
6.67 X 10^-11(445kg)(41.0kg)/2/(.42)^2?
Thank you
It's almost (but not quite) what I mean. What distance is "in the middle" from the other masses? I'm look for the actual distance, in meters, from "in the middle" to one end or the other.
Thank you
We can get to that later, but first it would be helpful to answer the distance question I asked above.
Well, in the problem it states that the two objects are separated by .420 m. Is that what you mean? Thus, the 41.0 object is at .420 m, right?
Thank you
Have you drawn a diagram of the 3 masses? You are just not picturing the arrangement correctly.
Sorry, I can't offer any more advice or hints to you.
13K
  • · Replies 18 ·
