A pasting lemma counterexample (of sorts)
  • Context: Graduate
  • Thread starter Thread starter dkotschessaa
    Counterexample
The discussion centers on the exploration of counterexamples to the pasting lemma in topology, specifically when one set is open and the other is closed. Participants propose various functions, such as ##f: (-\infty, 0] \cup \{1\} \rightarrow \mathbb{R}## defined by ##f(x)=1## and ##g: (0, \infty) \rightarrow \mathbb{R}## defined by ##g(x)=x##, to investigate the continuity of combined functions under these conditions. The conversation highlights the need for clarity in defining open and closed sets, with emphasis on the properties of the real numbers and their topology. Participants express a desire for further examples and clarification on the implications of the pasting lemma.
  • Understanding of the pasting lemma in topology
  • Familiarity with open and closed sets in the context of real numbers
  • Knowledge of continuous functions and their properties
  • Basic concepts of topology, including Hausdorff spaces
  • Research the properties of open and closed sets in topology
  • Explore examples of continuous functions and their discontinuities
  • Study the implications of the pasting lemma in various topological spaces
  • Investigate Hausdorff spaces and their significance in topology
Mathematicians, students of topology, and anyone interested in the nuances of continuity and the pasting lemma in mathematical analysis.
dkotschessaa
From the pasting lemma we have that if ## X = A \cup B ## and ##f: A \rightarrow Y ## and ## g: A \rightarrow Y## are continuous functions that coincide on ## A \cup B ##, they combine to give a continuous function ## h: X \rightarrow Y ## s.t. ## h(x) = f(x) ## for ## x \in A ## and ## h(x) = f(g) ## for ## x \in B ##, so long as both ## A ## and ## B## are both open or closed.
But what if ##A## is open and ##B## is closed? This should not work. My reasoning is that, if it worked, then the pasting lemma would already say so! But this obviously does not constitute a proof or counterexample. I think it shouldn't be difficult, but I am missing something. The "obvious" choice was to take ##A## and ##B## as complements, but I am not sure how to show a lack of continuity. The intersection is empty, so the functions agree on that. Another example?
I feel like this should be very easy or obvious. A nudge in the right direction would be appreciated.
-Dave K
With complementary sets ##A,B## one could define ##f: (-\infty,0) \rightarrow \mathbb{R}## by ##1/x## and ##g: [0,+\infty) \rightarrow \mathbb{R}## by ##g(x)=0##. It would be more interesting / challenging to find an example with ##A \cap B \neq \emptyset##.
Indeed it would. This works for the time being or at least gets me started. I think my mental block was that the functions I was coming up with were all onto their domain even though there is no good reason for this. Thanks.
In case you find an example with overlapping domains, please post it. I'm curious now. (And confident, that there are some - I mean it's topology, isn't it?)
Will do.
You can overlap the domains away from the problem points. Let X=S^1. The usual angle function S^1\to [0,2\pi) is of course discontinuous. But it continuous when restricted to the arc consisting of points with angles in [0,\pi] and also to the arc of points with angles in (\pi/2,2\pi) (notice that the first arc is a closed subset of S^1 and the second is a open).
Edit: One could also have just enlarged the domain of your functions, so that, for example, f is also defined on (0,1) and is zero here. But my example still holds if you want A and B to be connected.
Consider the functions ##f : (-\infty, 0]\cup\{1\} \rightarrow \mathbb{R} ##, defined by ##f(x)=1## and ##g: (0,\infty) \rightarrow \mathbb{R}##, defined by ##g(x)=x##.
Hey, I hadn't realized there were new posts on this thread. Thank you @Infrared and @Mayaka Ibara . I will check them out later.
Mayaka Ibara said:
Consider the functions f:(−∞,0]∪{1}→Rf:(−∞,0]∪{1}→Rf : (-\infty, 0]\cup\{1\} \rightarrow \mathbb{R} , defined by f(x)=1f(x)=1f(x)=1 and g:(0,∞)→Rg:(0,∞)→Rg: (0,\infty) \rightarrow \mathbb{R}, defined by g(x)=xg(x)=xg(x)=x.
Is this actually a counterexample to the modified pasting lemma, where one set is suppose to be open and the other closed? The set ##(0, \infty)## is open in ##\mathbb{R}## endowed with the standard topology, but ##(-\infty, 0] \cup \{1\}## doesn't seem closed to me...I must be missing something.
##(-\infty, 0] ## is closed since it's complement is ##(0, \infty)## which is open. The single point set ##\{1\}## is closed. (My reasoning - I know ##\mathbb{R}## is Hausdorff, implying it's ##T_1## so single point sets are closed. There might be an easier explanation.) So it's a union of closed sets.
Heaven help me if I'm wrong. My qualifier is in less than 60 days. :)
-Dave K
  • · Replies 0 ·
