A person travelling through a geodesic.
  • Thread starter Kevin_spencer2
  • Tags
    Geodesic
In summary, a person traveling through a geodesic will not experience any acceleration, as described by the geodesic equation. In an Euclidean space, there is no acceleration for a particle line. This means that if someone is following a geodesic, they will be in "free fall" and will not feel any acceleration. Even if they have an accelerometer, it will read zero. However, if a global coordinate system is set up, the second time derivatives of the position coordinates may be non-zero. This can be observed with an object orbiting a central mass in a circular orbit, where it is locally in free fall but globally the second time derivative of the spatial position coordinates will be non-zero.
Kevin_spencer2
29
A person traveling through a geodesic. Does experiment some kind of acceleration?, since the geodesic equation analogue to Newton one is:
[tex] \Delta _{u} u =0 [/tex] and in an Euclidean space there's no acceleration for a particle line [tex] X(u)=au+b [/tex]
Someone following a geodesic will be in "free fall". They won't feel any acceleration - if they have an accelerometer, it will also read zero. If you set up a global coordinate system, however, the second time derivatives of the position coordinates will in general be nonzero.
Think, for example, of an object orbiting a central mass in a circular orbit. Such an object is locally in free fall, and could set up a local coordinate system that is nearly inertial over small distances.
In a global coordinate system anchored to the central mass, the second time derivative of the spatial postion coordinates will be nonzero, however.
Yes, a person traveling through a geodesic may experience some kind of acceleration. This is because the geodesic equation, which is analogous to Newton's second law, states that the second derivative of the position vector with respect to the parameter u is equal to zero. This means that the acceleration of a particle on a geodesic is determined by the curvature of the space it is traveling through. In an Euclidean space, where the curvature is zero, there is no acceleration for a particle following a straight line. However, in a curved space, such as a geodesic, there may be non-zero acceleration due to the curvature of the space. Therefore, a person traveling through a geodesic may experience some kind of acceleration, depending on the curvature of the space they are traveling through.
What is a geodesic?
A geodesic is the shortest path between two points on a curved surface, such as the Earth's surface. It is the equivalent of a straight line on a flat surface.
How does a person travel through a geodesic?
In order to travel through a geodesic, a person would need to follow the curvature of the surface they are travelling on. This could involve going over mountains or around bodies of water, depending on the specific geodesic.
What are some practical applications of travelling through a geodesic?
Travelling through a geodesic can be useful in navigation, as it allows for the most efficient route between two points. It is also important in fields such as geology and cartography, as it helps to accurately represent the Earth's surface.
Are there any challenges associated with travelling through a geodesic?
One challenge of travelling through a geodesic is that it may not always be the most practical route. For example, it may require going through difficult terrain or crossing obstacles. Additionally, accurately calculating and following a geodesic can be challenging without the use of advanced technology.
Can a person travel through a geodesic on any surface?
A person can travel through a geodesic on any surface that is curved, such as a sphere or an oblate spheroid. However, on a flat surface, a geodesic would be a straight line and would not require any special navigation techniques.
