Mentor
- 37,249
- 16,373
@johnfrancismurray you should really pay attention to this post above by @IbixIbix said:It's worth noting that dividing the distance I measure you to travel by the time I measure you to take is a quantity called velocity. Dividing the distance I measure you to travel by the time you measure you to take is a quantity called celerity. The two values are always different, and celerity is indeed infinite for light (if one is careful in interpreting "time you measure" in terms of "interval along worldline").
So the OP is talking about something that exists in physics, but it's just a choice between two different quantities and not any kind of duality. Nobody uses celerity for anything that I'm aware of because everything it does velocity also does, and with less potential for mathematical problems.
Physicists use technical words with precise meanings. Speed is one of those words. The speed of light is a very specific quantity and it is finite, not infinite. Saying that it is infinite is simply wrong no matter how many ways you try to say it. In fact, the fact that the invariant speed is finite is the single key difference between relativistic and Newtonian mechanics.
There is a different quantity called celerity which has units of speed, and which goes to infinity as an object's speed goes to ##c## in an inertial frame. There are also related quantities called rapidity which is the hyperbolic angle between two four-velocities and which is infinite if one of those four-velocities is light like.
