A question on measurment in QM
  • Context: Graduate
  • Thread starter Thread starter wangyi
    Measurment Qm
The discussion revolves around the conservation of quantities in quantum mechanics (QM), particularly focusing on energy conservation during measurements. Participants explore the implications of measuring a non-eigenstate and the subsequent behavior of the system, addressing concepts such as wavefunction collapse and the relationship between observables and the Hamiltonian.
  • One participant questions whether conserved quantities in QM are conserved under all conditions, particularly when measuring a non-eigenstate of energy.
  • Another participant suggests that energy conservation can be violated as indicated by the uncertainty principle, \(\Delta E \Delta t \geq \frac{\hbar}{2}\).
  • It is noted that after a measurement, if the system is undisturbed, the same energy values will be obtained upon subsequent measurements.
  • A participant asserts that conserved quantities in QM are generally conserved under all conditions, though they acknowledge potential future developments that may challenge this view.
  • One participant explains that a measurement disturbs the system, causing the wavefunction to collapse into an eigenstate, which leads to consistent measurement results for that observable if no further disturbance occurs.
  • Another participant elaborates that if an observable commutes with the Hamiltonian, it will remain conserved over time, while non-commuting observables may not retain their eigenstate status as time progresses.
Participants express differing views on the conservation of quantities in QM, with some asserting that conservation holds under all conditions while others suggest that this may not always be the case. The discussion remains unresolved regarding the implications of measurements on energy conservation.
Participants reference the role of the Hamiltonian and the conditions under which observables are conserved, highlighting the complexity of the relationship between measurements and the state of a quantum system.
wangyi
Hi,
I don't know whether the conserved quantities in QM are conserved in every conditions. For example, a state can be a non-eigenstate of energy, and when we measure the energy of this state, it falls into an eigenstate of energy. The former state does not have a definite energy, but the latter has. And, another measurment may get another different energy. Does it mean energy is not exactly conserved or it means we give the system some energy when we are measuring them?
Thank you very much and happy new year!
being a freshman on the subject, here's a freshman reply:
the energy conservation can be violated by [tex]\Delta E \Delta t \geq \frac{\hbar}{2}[/tex]
Actually, after the measurement as long as the system is undisturbed until you measure the energy again, you will keep getting the same energy values. This is true for any observable.
Hi,
I think until today we know that the conserved quantities in QM are conserved in every conditions.
But in otherwise it may be not ,but it is in the future
As abszero said, a measurement on a system will disturb it in a fundamental manner. The wavefunction will 'collapse' into an eigenstate of the observable measured so an immediate measurement on the same quantity will yield the same result.
This is not the same as conservation of the physical quantity ofcourse. You could wait a while after the first measurement and let the state evolve according to the Schrödinger equation, then measure it again.
Energy eigenstates are called stationary states for the simple reason that the wavefunction only picks up a phase difference over time with no physical consequences, so it remains effectively in the same state. Energy is thus conserved.
So in general, a quantity will be conserved if its eigenstates are also energy eigenstates and that means the observable should commute with the hamiltonian.
This is true for any observable A (that doesn't have explicit time dependence) that commutes with the Hamiltonian. After a measurement of A, the state of the system is an eigenstate of A, but if A does not commute with the Hamiltonian, then, in general, as time progresses, the time evolution operator will evolve the system's state into a state that is not an eigenstate of A, even when no further measurements are performed. If A commutes with the Hamiltonian, then after a measurement of A, the time evolution operator always produces an eigenstate of A associated with the measured value of A.
This motivates the quantum mechanical definition that A is conserved if it commutes with the Hamiltonian.
Regards,
George
Edit: I see that while I was composing (I'm a very slow thinker and an even slower typist), Galileo already made the points that I wanted to make.
  • · Replies 24 ·
  • · Replies 17 ·
