Does entanglement synchronization change with distance in general relativity?
  • Context: High School
  • Thread starter Thread starter SchrodingersRat
15 replies · 2K views
SchrodingersRat
Hi everyone, this is my first post.
As anyone interested in physics I am somewhat familiar with the concept of entanglement. Also I have read that contrary to what most people think about this phenomenon, the particles involved are not always exactly synchronized but one can actually seem to be ahead of the other in time (time in the sense of what you measure with a clock). This would be hard to explain in a Newtonian-like formulation of physics but as they say this is not necessarily a problem with GR.
A question I have thought about regarding this, and one I am sure someone would have come up with an experiment to test, is how this effect changes with distance. That is, does the degree of de-synchronization compared to clocks increase linearly with distance? And are there other factors that can affect this behavior?
Also, is the de-synchronization different for every entangled particle pair or is there some form of correlation in every pair with roughly the same two positions? The first would seem to fit better with the rest of modern physics, but I my knowledge of QM is not that deep yet.
I have no idea what you mean by this. A system of particles in an entangled state is described by a single state that cannot be decomposed into a separate state for each particle.
Reply
:welcome:
Entangled systems are not "synchronized" as you imagine. They follow a set of rules that can be difficult to understand for the beginner. Generally: time and distance are not factors. Interaction with other quantum particles or systems is a factor. Entanglement can be full (maximal) or partial. Entanglement can occur on some bases (such as spin) but not on others (such as momentum). And entanglement can be between 2, 3, or more particles.
There are literally thousands of experiments in the canon on entanglement.
:smile:
Reply
Hi, and welcome to PF!
It would help if you could give some specific references to where you have read this.
However, I suspect what you are referring to is descriptions of experiments on pairs of entangled particles in which measurements are made on the particles at spacelike separated events--that is, it would be impossible for a light signal to travel from one measurement to the other. For spacelike separated measurements, their time ordering is frame-dependent--they can happen at the same time in one frame, but in other frames measurement A can happen before measurement B, or measurement B can happen before measurement A.
What this means from a physics perspective is not that the particles or the measurements on them get "desynchronized", but that the time ordering of the measurements cannot matter--in other words, the measurement results cannot depend on the order in which the measurements are made. (In more technical language, physicists will say that the measurements must commute.) That puts strong constraints on the types of physical models that can match the experimental results.
Reply
  • Agree
I feel a bit stupid now, but I don´t remember where I read this except that it was on the internet. Are you saying that there is not desynchronization but rather that it is not possible to determine in which order the measurements were made? Also I know that there is a phenomenon referred to as time-like quantum entanglement, could you tell briefly how it works and how it relates to regular entanglement?
In Special Relativity there is no absolute time. In particular, there is no universal simultaneity. Events that happen in the same place have a definite order. Events may however be "spacelike" separated, which means they have no definite order. It makes no sense to say which one absolutely happened first.
Reply
I know that you cannot measure absolute time in relativistic physics. But by desynchronization I mean what could be described as how close a "spacelike" separation is to being a "lightlike" separation.
Actually I found an article that answered these questions nicely. I´m sorry for taking up people´s time.
Reply
If possible, can you please post a link to the article so others who have the same question can understand.
I am just a casual amateur and would appreciate it.
Reply
Actually, I would say entanglement is an easier concept to understand in Quantum Field Theory (QFT). It's just an excitation of the underlying quantum field that permeates all space of two particles. The 'configuration' of such an excitation can be localised or spread across a large volume, just as a single particle can do the same. Until measurement, the particles are viewed as a single excitation rather than as two individual excitations, each of a single particle. When measured (i.e., interacting with something we call a measuring device), that tells us about a single particle, it becomes two separate excitations.
While I like this, it is not like if I can picture it better, because even with a classical field in mind I cannot get a sense of how it violates Bell inequalities.
Reply
Would the statement that the two entangled particles retain the same relationship to their underlying quantum field be consistent with your view? To me, that is a nice explanation for quantum entanglement without any issues about faster than speed of light communication, etc.
It would help if you replied to the post and statement that you are referring to.
That said, it's not clear to me how QFT makes any fundamental difference in terms of "explaining" entanglement and "non-locality". It's mathematically more sophisticated and a more general formulation of QM, but the fundamental issue of "non-locality" remains.
Basic QM is non-relativistic. The Schrodinger equation is explicitly not covariant. A particle can be found outside its future light-cone. QFT fixes that by incorporating SR, recognising that particles are not fundamental and embedding the maximum speed of causality into its mathematical structure.
Entanglement, however, is about correlation of measurements (not causation). As far as QFT is concerned, space-like separated measurements commute (i.e. do not depend on each other). That is mathematically compatible with space-like separated measurements on an entangled system being correlated. That remains bound up in the concept of an entangled (non-local) state. A two-particle wave-function has been replaced by a quantum field, but fundamentally the subtle distinction between causation and correlation remains.
Reply
Thank you for your thoughtful response. I was responding to Bhobba's statement ("I would say entanglement is an easier concept to understand in Quantum Field Theory (QFT)....", quoted more fully, below). He seems to think that QFT does help explain entanglement, and that seems to make sense to me:
What do you actually get from QFT in terms of entanglement? You can use relativistic QM (without going into field theory) and you still add nothing to the issue. So it is not relativity that is doing the work here. Is it the idea that you can replace two particles by a single space-encompassing field?
Yes, the concept I would throw out is that, perhaps, the entangled particles retain their same relationship to their underlying (and non-local) quantum field. So, even when they are separated by billions of miles, their spins (for example) would retain the same relationship to their underlying quantum field. So, as a result of this, the spins of the two entangled particles would continue to be correlated.
I do not know if Bhobba was saying the same thing. But, I have not read much content that views entanglement as related to QFT. So, his comment stood out to me. (I have occasionally read some materials that seem to suggest this, but nothing very concrete.)
