- 14,791
- 7,437
Completely agree.Dmitry67 said:To answer the question precisely we need to find an exact solution of the equation of the wavefunction for the whole universe close to t=0
Demystifier said:It is even less clear why a simulation of a human observer (not sharing all physical properties of a true human observer) WOULD qualify as a true human observer.
But then you also simulate decoherence existing in a true human observer. But I don't think that you can simulate decoherence without actual decoherence. So there is decoherence in this quantum computer. Of course, the computer as a whole is unitary and described by a pure state, while decoherence refers to subsystems only. In fact, I don't see any essential difference between this simulation of a human and an actual human. So what is the point of making this simulation anyway?Count Iblis said:If you wish you can consider a thought experiment in which you do simulate all the physical degrees of freedom using a quantum computer. The computational states of the quantum computer are then related to the precise physical states of a human being living in some isolated box via a unitary transformation.
Demystifier said:But then you also simulate decoherence existing in a true human observer. But I don't think that you can simulate decoherence without actual decoherence. So there is decoherence in this quantum computer. Of course, the computer as a whole is unitary and described by a pure state, while decoherence refers to subsystems only. In fact, I don't see any essential difference between this simulation of a human and an actual human. So what is the point of making this simulation anyway?
hamster143 said:The definition of a branch is closely tied with slicing up of the Hilbert space of the universe into smaller Hilbert spaces of its interacting constituents (which is, obviously, non-unique). If you view the big Hilbert space as a tensor product of a number of smaller spaces, that gives you a natural set of basis states and an evolution Hamiltonian, which, when applied to any basis state, will likely turn it into a superposition, thus "branching" it.
There is a preferred slicing that identifies conscious beings as basis states. It is convenient because these states are relatively stable. Under the action of Hamiltonian, a conscious being can remain the same (be an eigenstate), evolve in a slow and continuous manner (move), or occasionally undergo discrete branchings when it acquires new knowledge.
Demystifier said:Count Iblis, you might be interested in this:
https://www.physicsforums.com/showthread.php?t=347164
Perhaps, but not if the initial condition is perfectly symmetric.Dmitry67 said:Is this correct?
Demystifier said:Nice try! However, a superposition of nontrivial structures does not necessarily need to contain nontrivial structures. Indeed, in the case above it doesn't.
Take for example a constant function
f(x)=1 for all x
You can write this function as a sum of two (or more) very complicated functions. These functions may have nontrivial structures. Yet, the constant function above does not contain nontrivial structures. It is perfectly clear when f(x) represents some classical quantity. And the idea of MWI is that the wave function is also, in a certain sense, a "classical" quantity.
Demystifier said:Perhaps, but not if the initial condition is perfectly symmetric.
We can not talk probably about the decoherence until the very first primitive systems (hardrons, primitive nuclei) emerged. But stillthere were very primitive. As time frame of decoherence depends on the number of degrees of freedom, the decoherence at that time was very slow.
Until some time the whole evolution of the universe should be calculated as unitary and global, without any division to branches.
Is this correct?
hamster143 said:It is perfectly okay to have asymmetry arise out of symmetry. There's even a term for it - spontaneous symmetry breaking :) Think phase transitions.
There is no preferred basis in MWI.Count Iblis said:I think one needs to have an unambiguous recipe to define what the "nontrivial structure content" is. My opinion is that one has to expand the function in a certain preferred basis to extract this.
Demystifier said:There is no preferred basis in MWI.
This is not symmetric enough, in the sense that there are MANY DIFFERENT initial states that may lead to branchings of this sort. This is in contrast with your idea that the structures should emerge from a UNIQUE (i.e., much more symmetric, like a ground state) initial condition.Dmitry67 said:Why perfectly symmetric initial conditions in MWI can not evolve into a symmetric superposition of asymmetric states?
Take a box with 2 neutrons - one on the left and one on the right. The inital state is symmetric.
Now after a while left (or right) neutron decays.
in MWI it means that there are 2 branches (in fact there are much more branches) - left decayed first, right decayed first.
Demystifier said:This is not symmetric enough, in the sense that there are MANY DIFFERENT initial states that may lead to branchings of this sort. This is in contrast with your idea that the structures should emerge from a UNIQUE (i.e., much more symmetric, like a ground state) initial condition.
Dmitry67 said:Correct
It had recently hit me: while MWI is deterministic and objective, the 'Observer' is not defined in MWI objectively. Loss of realism we witness is not a result of the fact that nature is not realistic, but it is a projection of our own non-realism.
Take an observer Bob. Should we include his hair into the 'state of a system with microscopically many degrees of freedom'? What’s about molecules of H2O evaporating from his skin? A food inside his stomach? All these options give different 'preferred basis'
I would like to say that these bases are macroscopically consistent. Unfortunately it is difficult to define that consistency. It is not only branch-dependent, but branch is defined based on the decoherence, and decoherence uses basis.
So you don't know what the initial condition is. So the creator of the universe had a lot of choice. So, contrary to your claim, MWI is not better than BM in this regard.Dmitry67 said:You say: there are MANY OTHER initial conditions which can produce the same ASSYMETRY.
I agree. So what?
