A question with a time dependent Hamiltonian
The discussion revolves around solving the evolution of a two-state quantum system with a time-dependent Hamiltonian. The initial approach involved diagonalization of the Hamiltonian, leading to a change of basis that resulted in an incorrect application of the Schrödinger equation. Participants identified that the time-dependent change of basis matrix complicates the relationship between the state vectors and their derivatives. It was suggested that the transformation resembles a change of reference frame, akin to moving into a rotating frame in classical mechanics, which introduces fictitious forces. The conversation highlights the need to carefully consider the implications of time-dependent transformations in quantum mechanics.
dEdt
To cut to the chase, I have to solve for the evolution of a two-state system where the system's state at time t satisfies the equation
\mathrm{i}\hbar\left( <br /> \begin{array}{cc} <br /> \dot{c}_1(t)\\ <br /> \dot{c}_2(t)<br /> \end{array} <br /> \right)=\left(<br /> \begin{array}{cc} <br /> 0 &amp; \gamma \mathrm{e}^{\mathrm{i}(\omega - \omega_{21})t}\\ <br /> \gamma \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; 0 <br /> \end{array} <br /> \right)\left(<br /> \begin{array}{cc} <br /> c_1(t)\\ <br /> c_2(t)<br /> \end{array} <br /> \right)
with initial conditions c_1(0)=1 and c_2(0)=0.
I decided to solve this by diagonalization. The eigenvectors of the Hamiltonian are
\frac{1}{\sqrt{2}}\left(<br /> \begin{array}{cc} <br /> \mathrm{e}^{\mathrm{i}(\omega - \omega_{21})t}\\ <br /> 1<br /> \end{array} <br /> \right) and \frac{1}{\sqrt{2}}\left(<br /> \begin{array}{cc} <br /> \mathrm{e}^{\mathrm{i}(\omega - \omega_{21})t}\\ <br /> -1<br /> \end{array} <br /> \right), with eigenvalues \gamma and -\gamma, respectively.
The change-of-basis matrix then is just
U^\dagger = \frac{1}{\sqrt{2}}\left( <br /> \begin{array}{cc} <br /> \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; 1\\ <br /> \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; -1<br /> \end{array} <br /> \right). So in the new basis, the state vector becomes
\frac{1}{\sqrt{2}}\left( <br /> \begin{array}{cc} <br /> \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; 1\\ <br /> \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; -1<br /> \end{array} <br /> \right)\left(<br /> \begin{array}{cc} <br /> c_1(t)\\ <br /> c_2(t)<br /> \end{array} <br /> \right):=\left(<br /> \begin{array}{cc} <br /> d_1(t)\\ <br /> d_2(t)<br /> \end{array} <br /> \right).
Therefore, we have
\mathrm{i}\hbar\left(<br /> \begin{array}{cc} <br /> \dot{d}_1(t)\\ <br /> \dot{d}_2(t)<br /> \end{array} <br /> \right)=\left(<br /> \begin{array}{cc} <br /> \gamma &amp; 0\\ <br /> 0 &amp; -\gamma<br /> \end{array} <br /> \right)\left(<br /> \begin{array}{cc} <br /> d_1(t)\\ <br /> d_2(t)<br /> \end{array} <br /> \right)
which can be solved easily. Once the d's are found, the c's are easily computed.
Problem is, this doesn't give the right answer. I suspect it has something to do with using a time-dependent change of basis matrix, but I'm not sure.
I think your suspicions are right.
From \mathrm{i}\hbar\left( <br /> \begin{array}{cc} <br /> \dot{c}_1(t)\\ <br /> \dot{c}_2(t)<br /> \end{array} <br /> \right)=\left(<br /> \begin{array}{cc} <br /> 0 &amp; \gamma \mathrm{e}^{\mathrm{i}(\omega - \omega_{21})t}\\ <br /> \gamma \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; 0 <br /> \end{array} <br /> \right)\left(<br /> \begin{array}{cc} <br /> c_1(t)\\ <br /> c_2(t)<br /> \end{array} <br /> \right)
You can write
\mathrm{i}\hbar U^\dagger \left( <br /> \begin{array}{cc} <br /> \dot{c}_1(t)\\ <br /> \dot{c}_2(t)<br /> \end{array} <br /> \right)= U^\dagger \left(<br /> \begin{array}{cc} <br /> 0 &amp; \gamma \mathrm{e}^{\mathrm{i}(\omega - \omega_{21})t}\\ <br /> \gamma \mathrm{e}^{-\mathrm{i}(\omega - \omega_{21})t} &amp; 0 <br /> \end{array} <br /> \right) U U^\dagger \left(<br /> \begin{array}{cc} <br /> c_1(t)\\ <br /> c_2(t)<br /> \end{array} <br /> \right) = \left(<br /> \begin{array}{cc} <br /> \gamma &amp; 0\\ <br /> 0 &amp; -\gamma<br /> \end{array} <br /> \right)\left(<br /> \begin{array}{cc} <br /> d_1(t)\\ <br /> d_2(t)<br /> \end{array} <br /> \right)
But the left hand side cannot be equated to ##\mathrm{i}\hbar\left(
\begin{array}{cc}
\dot{d}_1(t)\\
\dot{d}_2(t)
\end{array}
\right)## due to the time dependence of ##U^\dagger##:
##\left(
\begin{array}{cc}
\dot{d}_1(t)\\
\dot{d}_2(t)
\end{array}
\right) = \frac{d}{dt} \left(U^\dagger \left(
\begin{array}{cc}
c_1(t)\\
c_2(t)
\end{array}
\right)\right) \neq U^\dagger \left(
\begin{array}{cc}
\dot{c}_1(t)\\
\dot{c}_2(t)
\end{array}
\right)##
you just need to write the two eqns represented by them,differentiate the second one and put the values from the first one.That's all.
\begin{array}{cc}
\dot{d}_1(t)\\
\dot{d}_2(t)
\end{array}
\right)##
I understand your reasoning, and I can't find a flaw with it, but the conclusion is really bothersome. It's as if the state doesn't obey the Schrödinger equation if its matrix representation uses energy eigenkets as a basis. But how can that be right?
I'll have to do this I guess, but I'd like to see why my approach doesn't work.
Anyone?
dEdt said:
I understand your reasoning, and I can't find a flaw with it, but the conclusion is really bothersome. It's as if the state doesn't obey the Schrödinger equation if its matrix representation uses energy eigenkets as a basis. But how can that be right?I'll have to do this I guess, but I'd like to see why my approach doesn't work.
TSny showed you why it doesn't work. I'm not sure exactly what you mean when you say "It's as if the state doesn't obey the Schrödinger equation if its matrix representation uses energy eigenkets as a basis". In what way does it appear to you to not obey the Schrödinger equation?
Perhaps the issue is that your "change of basis" - your unitary transformation - is really a change of reference frame. You are moving into a rotating frame. There are no true energy eigenkets for this system because the energy is not conserved in time (though it is conserved on average). Perhaps one can say this is similar to the case in classical mechanics: when you move into a rotating frame in classical mechanics you generate "ficticious forces" into Newton's equations of motion. Similarly, your change of reference frame here is generating what look to you like new terms into Schrödinger's equation.
I don't have a quantum book handy right now, but this is (or is pretty similar to) a fairly standard example of a spin in a rotating magnetic field. A book on NMR that treats the problem quantum mechanically should have a discussion, though I don't know if it would exactly address your philosophical problem.
Thanks, now it makes sense.
  • · Replies 28 ·
  • · Replies 19 ·
