A rope, a pole, and some tension
  • Thread starter Thread starter Quantum Psi Inverted
    Pole Rope Tension
The discussion revolves around a problem involving a rope wrapped around a pole and the forces acting on it, specifically focusing on the tension in the rope and the effects of static friction. The context is rooted in classical mechanics, particularly related to tension forces and frictional interactions.
  • Participants explore how tension varies along the rope and question the implications of treating the rope as massless. There is a discussion about the relationship between the forces acting on the rope and the role of friction.
The discussion is ongoing, with participants providing insights and references to external resources. Some participants express confusion about the assumptions made regarding the rope's mass and the nature of the forces involved. There is no explicit consensus yet, but various interpretations and clarifications are being explored.
There are references to specific diagrams and external resources, such as the Capstan equation, which may not directly apply to the current scenario. The finite size of the pole is noted as a relevant factor, although its exact dimensions are not specified.
Thread moved from the technical forums to the schoolwork forums
A rope wraps an angle θ around a pole. You grab one end and pull with a tension T0. The other end is attached to a large object, say, a boat. If the coefficient of static friction between the rope and the pole is µ, what is the largest force the rope can exert on the boat, if the rope is not to slip around the pole?
I'm struggling to understand the diagram depicted here:
Could someone explain why this diagram would help us? This is the David Morin Classical Mechanics book if that helps whatsoever.
Welcome to PF.
Is this homework?
Consider a rope that passes one turn around a fixed cylinder. Then consider two turns.
The force that pulls the rope onto the friction cylinder surface, is determined by the tension you apply to the "free" end of the rope, that you are holding.
How does the tension vary along the rope?
Ah! When you put it that way, everything makes sense now. Thank you very much.
If the rope is taken to be massless the tension is the same everywhere!
No, no! Please withdraw that.
ok tell me where is the mistake, we take a portion dx of the rope at position x, if the rope is massless from newtons 2nd T(x+dx)-T(x)=dma=rdxa, r=0 so unless we have infinite acceleration T(x+dx)-T(x)=0 hence T constant everywhere.
There is a normal force from the pole, as shown, and friction parallel to the rope.
Follow the link in post #4.
Hm. Ok so it is the same along each segment of the rope, but between the two segments it is different?
Capstans btw is for different situation, rope multiple tied around a pole with dimensions, here the rope just does a single tie around a dimensionless pole.
The pole is not point-like. It has a finite size. Although the diameter of the pole is unknown, that diameter will turn out to be irrelevant. The diagram is a strong hint that this is the intent.
The text indicates that there are two forces. One unknown force from the boat and one known force from you (the person holding the other end of the rope).
I've cinched up more than a few ropes wrapped around trees. And tied off mooring ropes to a fair number of cleats. I assure you that the scheme is viable.
The fixed cylinder, or bollard, is used to hold a large tension force, by multiplying the small tension force that can be applied by a person. The person cannot pull the object providing the large force nearer, but by reducing the hand tension, can hold or control it as it moves away.
A capstan is a rotating cylinder. The capstan obeys the same physics and mathematics as the bollard. The difference with the capstan is that the person can provide a high force to move a heavy object, by pulling gently with a hand on the end of the rope. The work is then being done by the capstan motor.
  • · Replies 32 ·
  • · Replies 18 ·
