A simple angular velocity with two spheres problem
1 reply · 1K views · last reply
dennislam
Two masses have same mass m, both of them are tied by a string and put in a hollow cylinder.
When the cylinder start to rotate until the angular speed is ω.
The tension in the string is T and the string breaks, both masses move away from the axis in the hollow cylinder.
Diagram of two equal masses m joined by a horizontal string through the centre of a hollow cylinder, with the string tension T labelled, rotating about a vertical axis with angular velocity ω, radius r marked.
T=mrω^2
I have no idea about whether the tension T is equal to mrω^2 or 2mrω^2 (since there is two masses)
Please help!:cry:
sorry for my bad english
If you pull a spring with a force F, the spring pulls back with a force F. The tension in the spring is F, not 2F.
Same with a rope. In the situation described, but e.g. also if the rope hangs over a pulley and the two masses both pull down with ##mg##. Tension is ##mg##, not ##2mg##
