A skeptic's view on Bohmian Mechanics
235 replies · 32K views · last reply
I just wanted to say to the participants above (especially Arnold Neumaier, demystifier, rubi) that I very much enjoyed reading the back and forth. Although I doubt many minds were changed, the scope and intensity of the debate was very enlightening to me.
Thanks! :smile:
Even if we haven't changed our minds, at least we sharpened our arguments. :smile:
I couldn't agree more. And you responded with grace at each step. Not easy from those two, coming at you from every side. :smile: I give everyone kudos for making their strongest arguments. You had me following links to some material I had not seen before (there's a lot of that it seems).
Demystifier said:
In BM ##P=|\Psi|^2##, where ##\Psi## is the conditional wave function.
Okay, I actually had this in mind, too. But isn't this also the distribution with respect to which expectation values are computed?
Demystifier said:
As I already said, there is no point in arguing about BM as we (you and me) cannot even agree of the foundations of classical statistical mechanics, or even on the concept of probability. I wish you a good luck with your thermal interpretation inspired by your own interpretation of thermodynamics and statistical mechanics. :smile:
All my arguments here are solely about the shut-up-and-calculate part of probability, statistics, and Bohmian mechanics. Thus they are independent of the details how one interprets probability or thermodynamics or statistical mechanics.
No they are not. You neither shut up nor calculate. :-p
To clarify those things completely, one would need to rewrite the equations of BM in the language of Bell's theorem. As far as I am aware, nobody, not even Bell himself, has done it explicitly.
The important question is: Does BM involve fine tuning of initial conditions? For if it does, then it is superdeterministic. Well, the catch is that "fine tuning" is not a precisely defined concept. BM assumes quantum equilibrium at the beginning of the experiment. Bohmians don't think of it as "fine tuning", but some critiques, like Neumaier, think of it as fine tuning. It is somewhat subjective, but if you want to call quantum equilibrium "fine tuning", then yes, BM is "superdeterministic". But even if one calls it "superdeterminism", it is a rather soft kind of superdeterminism, much softer than superdeterminism needed in local theories.
I don't understand why this is not immediate. Aren't the particle positions ##\vec x## supposed to be the hidden variables and aren't they supposed to be distributed according to ##\left|\Psi\right|^2##? If that is the case, then the spin along some axis should be given by some functions ##A,B(\vec x,\vec a,\vec b)## and the correlations should be given by ##\int A(\vec x,\vec a,\vec b) B(\vec x,\vec a,\vec b) \left|\Psi\right|^2\mathrm d\vec x##. Now the question is whether ##\left|\Psi\right|^2## depends on ##\vec a##,##\vec b##, but it seems to me that it does, because BM must model the measurement apparatus and the environment in order supposedly reproduce QM and of course the angles ##\vec a##, ##\vec b## are some functions of the hidden variables ##\vec x##, because they are determined by the positions of the atoms that make up the apparatus. Hence, it seems to be that BM meets Bell's definition of superdeterminism. It wouldn't be that way if BM would work without taking the measurement theory into account, but we learned in the last thread that it won't reproduce QM this way.
What makes the BM superdeterminism softer than the superdeterminism required in local hidden variable theories?
During the night I have thought about all this once again (thank you for asking good questions that force me to think more carefully), and now I have some new insights. :woot:
Now my central claim is this: The fact that ##P(\lambda, \vec a,\vec b)## depends on ##\vec a##, ##\vec b## does not automatically imply that the theory is superdeterministic.
To explain this claim, let me present a counterexample: 18th and 19th century physics! Supoose that the world is described by classical non-relativistic mechanics, in which all forces are either Newton gravitational forces or Coulomb electrostatic forces. These forces involve an action over distance, so the laws of physics are nonlocal. Let ##\vec a## and ##\vec b## be positions of two macroscopic charged balls. They produce electric field which, nonlocally, influence the motion of all other charged particles. Let ##\lambda## be the positions and momenta of all atoms in the air around the balls. The atoms are hidden variables of 18th and 19th century, so ##\lambda## is a hidden variable. Furthermore, let us introduce probability in this deterministic theory by taking elements of Boltzmann statistical mechanics. We assume that atoms of the air are in a thermal equilibrium (which is an analogue of quantum equilibrium in BM). The motion of atoms depends on the electric field produced by the balls, so the Hamiltonian describing the motion of ##\lambda## depends on ##\vec a## and ##\vec b##. Hence the Boltzmann distribution is a function of the form
$$P(\lambda | \vec a,\vec b)$$
Note that ##P(\lambda | \vec a,\vec b)## is conditional probability, which should be distinguished from joint probability ##P(\lambda, \vec a,\vec b)##. They are related by the Bayes formula
$$P(\lambda | \vec a,\vec b)=\frac{P(\lambda, \vec a,\vec b)}{P(\vec a,\vec b)}$$
where
$$P(\vec a,\vec b)=\int d\lambda \, P(\lambda, \vec a,\vec b)$$
is marginal probability.
Now what is superdeterminism? Superdeterminism means that ##\vec a## and ##\vec b## cannot be chosen independently. In other words, superdeterminism means that
$$P(\vec a,\vec b)\neq P_a(\vec a) P_b(\vec b)...(Eq. 1)$$
where
$$P_a(\vec a)=\int d\lambda \int d^3b \, P(\lambda, \vec a,\vec b)$$
and similarly for ##P_b##. So is non-local classical mechanics superdeterministic? It can be superdeterministic in principle! Nevertheless, it is not superdeterministic in FAPP (for all practical purposes) sense. Even though there are forces between the charged balls, which in principle can make them correlated, in practice we can choose the positions ##\vec a## and ##\vec b## of the balls independently. That's because the force falls off with the distance, so the mutual influence between ##\vec a## and ##\vec b## can be neglected when the balls are very far from each other. Therefore ##\vec a## and ##\vec b## are not correlated FAPP, so classical non-local mechanics is not superdeterministic FAPP.
Now Bohmian mechanics. I hope the analogy between the example above and BM is quite clear. There is only one important difference. In BM, the non-local force does not fall off with distance. Nevertheless, the mutual influence between ##\vec a## and ##\vec b## can also be neglected. That's because ##\vec a## and ##\vec b## are orientations of macroscopic apparatuses, and decoherence destroys entanglement (in a FAPP sense) between macroscopic degrees of freedom. Without entanglement (in the FAPP sense) there is no correlation between ##\vec a## and ##\vec b##. And without correlation, that is when (Eq. 1) becomes equality, there is no superdeterminism.
The only thing I didn't explain is the following. If ##P(\lambda|\vec a,\vec b)## does not imply superdeterminism (in FAPP sense), what is the justification for using ##P(\lambda)## in the Bell theorem? I don't know at the moment, but let me tell that there are proofs of non-locality which do not rest on explicit introducing of ##\lambda##, and personally I like such proofs much more. An example is the Hardy proof of non-locality, reviewed e.g. in my
https://arxiv.org/abs/quant-ph/0609163
The way I understand it is that it is the assumption of locality, together with the Bell's inequalities, that suggests superdeterminism. In deriving the Bell inequalities, we can write:
[itex]P(A,B | \alpha, \beta) = \sum_\lambda P(\lambda | \alpha, \beta) P(A | \alpha, \beta, \lambda) P(B | \alpha, \beta, \lambda, A)[/itex]
(where, as usual, [itex]A[/itex] is Alice's result, [itex]B[/itex] is Bob's result, [itex]\alpha[/itex] is Alice's setting, [itex]\beta[/itex] is Bob's setting, and [itex]\lambda[/itex] is some hidden variable that is a potential common influence to Alice's and Bob's measurements.)
This form is perfectly general (I think); it is not hard to come up with a model of this sort that satisfies the quantum predictions for EPR. But assuming locality and no-superdeterminism further constrains the probabilities:
  • [itex]P(\lambda | \alpha, \beta) = P(\lambda)[/itex]
If [itex]\lambda[/itex] is a common influence to both Alice's and Bob's measurements, then it must be determined in the intersection of their backwards lightcones. But (assuming no-superdeterminism), the choice of [itex]\alpha[/itex] and [itex]\beta[/itex] can be made at the last moment, too late to influence [itex]\lambda[/itex].
We can similarly argue from locality and no-superdeterminism that
  • [itex]P(A|\alpha, \beta, \lambda) = P(A|\alpha, \lambda)[/itex]
  • [itex]P(B|\alpha, \beta, \lambda, A) = P(B|\beta, \lambda)[/itex]
So the final assumed form of the probability distributions is determined by locality and "free will" (no-superdeterminism):
  • [itex]P(A, B|\alpha, \beta) = \sum_\lambda P(\lambda) P(A|\alpha, \lambda) P(B|\beta, \lambda)[/itex]
And of course, Bell shows that no such model can reproduce the predictions of QM for EPR.
If you aren't assuming locality, then there is no problem in letting [itex]\lambda[/itex] depend on [itex]\alpha[/itex] and [itex]\beta[/itex], even if they are chosen at the last minute, as long as the choices are made before either measurement.
In the case where, for example, Bob's choice is made after Alice's measurement, then the above analysis doesn't quite apply, since in that case, [itex]\lambda[/itex] cannot depend on [itex]\beta[/itex]. But if we don't assume locality, then Bob's result can depend on Alice's result, so again, there is no problem with Bell's inequality.
And if we look at the situation at some earlier time when ##\vec a## and ##\vec b## is not yet set but instead we have only (yet to be determined) outputs or random number generators ##rnd_a## and ##rnd_b##? These random numbers don't have the type of influence as in your classical analogue. And that is the type of dependency that we call superdeterminism (dependency between ##\lambda## and ##rnd_a##, ##rnd_b##).
On the other hand if, at the moment when we set ##\vec a## or ##\vec b##, distribution of ##\lambda## changes and becomes dependent on ##\vec a## or ##\vec b## it would be non-locality instead of superdeterminism.
I guess you mean psudo-random, not trully random, right? If so, then it has a classical analogue because thermal fluctuations of classical atoms=##\lambda## can serve as a pseudo-random generator.
Superdeterminism is not when ##rnd_a## and ##rnd_b## depend on ##\lambda##. Superdeterminism is when this dependence is such that ##rnd_a## is correlated with ##rnd_b##. As I have explained, such a correlation is FAPP absent in both classical and Bohmian mechanics.
That doesn't follow. If you have a statistical description of the situation, you can integrate out the short scales ("renormalize") and thereby obtain an effective model that describes only the long range effects. In general, you will obtain extra terms that correspond to a long range correlation, even though your initial model only contained short-range interactions. (See the Ising model for example.)
I don't think that decoherence will destroy correlations. It makes certain interference terms go away, which results in expectation values peaked on classical trajectories. However, classical trajectories needn't loose their correlations.
Proofs like Hardy or GHZ aren't proofs of non-locality. They rather show that hidden variable models must be contextual, which can't be deduced from Bell's inequality alone. And they don't exclude superdeterministic models either.
This is not a locality assumption. It just enforces that the angles ##\alpha##, ##\beta## aren't correlated with ##\lambda##. If that condition is violated, it is still possible that the reason for the correlation of ##\alpha## and ##\beta## lies in the common past. Thus the condition is not related to locality. It merely enforces that the angles can be freely choosen instead of being determined (possibly by the common past).
So you think that classical mechanics is superdeterministic?
I do (in FAPP sense, of course).
Nobody ever observed them, which confirms my claim that they are FAPP absent. To repeat, they are possible in principle, but impossible FAPP.
Well, Hardy takes it as a proof of nonlocality.
Sure, they show that too. See my paper I mentioned above where I discuss it in more detail.
But for [itex]\alpha[/itex] and [itex]\beta[/itex] to be correlated would be superdeterminism. [itex]\alpha[/itex] is the measurement choice made by Alice, and [itex]\beta[/itex] is the measurement choice made by Bob. They are free to use whatever means they like to make that choice. For the choices to be correlated is superdeterminism.
RockyMarciano said:
Because they are the same in the EPR definition of realism as deterministic.
You are probably right that EPR criterion is the reason why many think that non-realism and non-determinism are the same. Thank you for that insight!
But it is a misinterpretation of the EPR criterion. The EPR criterion says something like "If we can predict with certainty ... then there is an element of reality ..." So according to EPR, determinism implies reality. However, the converse is not true; reality does not imply determinism. Therefore determinism and reality are not equivalent, and not the same. The GRW theory is a well-known example of a theory (compatible with QM) which has elements of non-deterministic reality.
Depends on the particular model. I'm just telling you that the short-rangedness of interactions in general leads to long-range correlations, which you denied. Also, in CM, the state isn't fine-tuned and the absence of correlations can then be justified on the basis of molecular chaos. However, in BM, the hidden variables must be distributed according to ##\left|\Psi\right|^2##, which is a restriction on the allowed distributions that can in principle introduce correlations.
However, that's just an opinion. I demand proof. If the wave-function evolves unitarily, correlations shouldn't go away, but rather propagate to finer parts of the system.
Nobody ever observed them.
That doesn't invalidate the argument.
He's wrong. Consistent histories is local despite allowing the Hardy state, so locality can't be ruled out by the argument.
Which is what I'm saying. The ##P(\lambda|\vec a,\vec b)=P(\lambda)## condition prohibits superdeterminism, but it is unrelated to locality. The question remains: How can BM be non-superdeterministic despite violating this condition?
Let it be pseudo-random. Why does it matters?
Look, if we can set hidden variable so that spin of entangled particles is always opposite in either measurement basis of Alice or Bob then we can violate Bell inequalities just as QM does.
I will use photons. Let's say entangled photons have opposite linear polarization in Alice's measurement base. Alice's measurement will give certain outcome based on two possible options HV or VH. Bob's measurement will give probabilistic outcome according to Malus law ##P=\sin^2(\beta-\alpha)## or ##P=\cos^2(\beta-\alpha)##. And that is all we need to replicate predicted correlations of QM.
This is how superdeterminism can violate Bell's inequality. And there is no need for ##\alpha## to be correlated with ##\beta##.
I disagree; it's the combination of no-superdeterminism and locality that prevents [itex]\lambda[/itex] from depending on [itex]\vec{a}[/itex] and [itex]\vec{b}[/itex]. If the choice of [itex]\lambda[/itex] is only made after Alice and Bob make their choices, then it doesn't imply superdeterminism, but it does imply nonlocality, since Alice's choice influences the [itex]\lambda[/itex] that in turn influences Bob's result.
If ##P(\lambda|\vec a,\vec b)## depends on ##\vec a## and ##\vec b##, it just means that it is possible that ##\vec a## and ##\vec b## depend on ##\lambda##. Let's say ##\lambda## is in the intersection of the past light cones. A local theory can perfectly well violate ##P(\lambda|\vec a,\vec b)=P(\lambda)##. You prepare two particles in the non-entangled state ##\left|\vec a\right>\otimes\left|\vec b\right>## and before you send the particles to Alice and Bob, you send Alice to order to align her detector along ##\vec a## and you do the same with Bob. This introduces a perfectly local dependence of ##\vec a## and ##\vec b## on the prepared state. So obviously, the condition can easily be violated in a local theory. Hence, it is not required by a local theory to satisfy the condition.
Can you give a concrete example, where the correlations refer to macro objects?
Yes, but "molecular chaos" often means Boltzmann distribution, i.e. thermal equilibrium.
This is quantum equilibrium, which is analogous to thermal equilibrium above.
In principle yes, but FAPP no.
Now you sound like Neumaier. Science is not about proofs. Science is about evidence. For evidence, see the book by Schlosshauer on decoherence.
Yes, and precisely because they are in the finer parts, they are not visible FAPP.
That's because CH forbids the classical rules of logic, while Hardy proof of nonlocality uses classical rules of logic. My opinion is that the rules of logic should be universal for all science, be it classical physics, quantum physics, or beyond quantum physics.
You measure two far away spins in an Ising lattice. The pointers of the measurement apparata will be correlated if ##T\leq T_\text{crit}##. This is important for harddisks.
Yes, but "molecular chaos" really means Boltzmann distribution, i.e. thermal equilibrium.This is quantum equilibrium, which is analogous to thermal equilibrium above.
But ##\left|\Psi\right|^2## changes depending on ##\Psi## and specific ##\Psi## can have a form that contains correlations. On the other hand, the Boltzmann distribution is a distribution of minimum entropy. It is even the marginal of a uniform distribution on some constant energy surface. So the amount of possible correlations are minimal. The lack of correlations in the Boltzmann distribution does not at all imply that the same must hold for ##\left|\Psi\right|^2##.
Again, this requires proof.
I know Schlosshauers book. Theoretical physics is of course about proofs. It's about stating some axioms and showing that they imply certain facts about physics. Of course, the level of rigor may vary, but the arguments must be convincing and continuously improved. Evidence is what we get from experimental physics. Proof (rigorous or not) is what theoretical physics is about. One can't simply postulate a claim in science. One always needs to justify it.
I don't think this has been established. In unitary evolution, entanglement is supposed to spread to macroscopic objects, like Schrödingers cat. Decoherence just makes interference terms between the individual branches of the wave-function go away. However, within each branch, the correlations remain.
CH doesn't forbid the classical rules of logic. On the contrary, it saves the classical rules of logic. As I have explained in the last thread, without the single framework rule of CH, the classical rules of logic are violated experimentally and there is nothing we can do about it (except argue only about logically consistent statements, which are singled out by the single framework rule of CH).
Only in a very formal way. It throws common sense and reality away.
I think there is a confusion about what the notation means. I'm assuming that [itex]\vec{a}[/itex] and [itex]\vec{b}[/itex] are the measurement choices made by Alice and Bob, respectively. The twin pair is prepared before those choices are made.
It's not worse than Copenhagen and it actually clarifies Copenhagen a lot.
Yes, sure, but it's perfectly possible and compatible with locality that the choices are determined by the preparation procedure of the twin pairs. This is superdeterminism. It will violate the condition, despite being completely local. Hence, the violation of the condition is compatible with locality. The exclusion of non-locality in Bell's proof is purely due to the requirements on the observables ##A## and ##B##.
The way that I understand consistent histories (which is not all that well), there is a sense in which there is no dynamics. The laws of quantum mechanics (such as Schrödinger's equation, or QFT) are used to derive a probability distribution on histories. But within a history, you've just got an unfolding of events (or values of mutually commuting observables). You can't really talk about one event in a history causing or influencing another event. Locality to me is only meaningful in a dynamic view, where future events, or future values of variables are influenced by current events or current values of variables.
Right. If you assume locality, then the dependence of the measurement choices on [itex]\lambda[/itex] implies superdeterminism. But if you don't assume locality, then the dependence of [itex]\lambda[/itex] on the measurement choices doesn't imply superdeterminism.
Don't get me wrong - I actually respect immensely that the CH people have really done pursued the initial idea very conscientiously (and yes, the initial idea was worth pursuing, even if it ended that we cannot have a single fine-grained reality). And CH's conception of locality and the Bell inequalities is far better than Werner's wrong headed criticism of Bohmian Mechanics.
However, I think Copenhagen is superior to CH. Copenhagen retains common sense and is more broadminded. Copenhagen is consistent with all interpretations (BM, CH, MWI), whereas I don't see how CH is consistent with BM.
Fine, let us say that I can't prove (with a level of rigor that would satisfy you) that BM is not superdeterministic. Can you prove that it is? As you can see, your arguments so far didn't convince me, and I claim (again, without a proof) that your arguments wouldn't convince Bell.
Anyway, if you claim that BM is superdeterministic, this is certainly an important claim (provided that it is correct), so I would suggest you to try to convince a referee of an important physics journal.
