What is the cross ratio of points on a sphere?
  • Thread starter Thread starter Mathmos6
The cross ratio of points on a sphere is defined as -tan²(d/2), where d is the angular distance between points P and Q on S². Given points u and v in the complex plane corresponding to P and Q, the points -1/u* and -1/v* represent their stereographic projections. By selecting the projection point at the midpoint of PQ, the four projected points align linearly at distances ±tan(d/4) and ±1/tan(d/4) from the origin, facilitating the calculation of the cross ratio without needing to evaluate all permutations.
  • Understanding of complex numbers and their conjugates
  • Familiarity with spherical geometry and angular distances
  • Knowledge of stereographic projection techniques
  • Basic grasp of cross ratios in projective geometry
  • Study the properties of cross ratios in projective geometry
  • Learn about stereographic projection and its applications
  • Explore angular distances on spheres and their geometric implications
  • Investigate the relationship between complex numbers and geometry
Mathematicians, geometry enthusiasts, students studying complex analysis, and anyone interested in the geometric properties of spheres and projective geometry.
Mathmos6
Hi all,
I wasn't sure whether to ask this here or not, but I've tried to make progress and so far had no such luck. I've not managed to make any headway on this so far, I don't think I can quite get my head around the geometry that's in play.
If u,v\in \mathbb{C} correspond to points P, Q on S^2, and d denotes the angular distance from P to Q on S^2, show that -\tan^2(\frac{d}{2}) is the cross ratio of the points u, v, \frac{-1}{u^*}, \frac{-1}{v^*}, taken in an appropriate order (which you should specify). (The star denotes complex conjugation - I'm not sure how to do the 'bar' in latex!)
Now I'm useless at geometry, but if I recall correctly, \frac{-1}{u^*} would correspond to the stereographic projection of the point (-P), right? And likewise with v - other than that however, I really can't see a smart way to do this. I certainly don't want to try all 6 permutations of the 4 points and see what pops up on the cross ratio, but at the same time I can't see intuitively where the -\tan^2(\frac{d}{2}) could have come from in order to try and work out how to take the cross ratio to get the desired result. I'm aware that the angle between the 2 points P and Q is equal to d, but I can't seem to work anything out in the complex plane rather than the sphere. Please help!
Many thanks in advance.
Anyone? I'll take any help you can offer! Thankyooou :)
Hi Mathmos6! :smile:
If you choose your projection point at the midpoint of PQ, then the four projected points are in a line at distances ±tan(d/4) and ±1/tan(d/4) from the origin. :wink:
Thanks so much, i didn't appreciate that the cross ratio is invariable under rotation so you can just place the points in a more convenient position and work it out that way. Have a good day!
  • · Replies 36 ·
