How Does Water Affect the Net Force on a Submerged Stone?
The discussion centers on the application of Archimedes' principle and the calculation of buoyant force acting on a submerged stone. The formula for buoyant force is established as F_b = -ρVg, where ρ is the fluid density, V is the volume of the displaced fluid, and g is the acceleration due to gravity. Participants clarify the distinction between scalar and vector quantities, emphasizing that gravitational acceleration g is a scalar while F_b is a vector. The conversation concludes with the importance of consistent notation in physics to avoid confusion in calculations.
  • Understanding of Archimedes' principle
  • Knowledge of buoyant force calculations
  • Familiarity with vector and scalar quantities
  • Basic principles of fluid mechanics
  • Study the derivation of Archimedes' principle in detail
  • Learn about the implications of buoyancy in different fluid scenarios
  • Explore vector notation and its application in physics
  • Investigate real-world applications of buoyant force in engineering
Students of physics, educators teaching fluid mechanics, and engineers involved in design and analysis of submerged structures will benefit from this discussion.
rudransh verma
A stone of mass 10kg is lying at the bed of a lake 5m deep. If the relative density of the stone is 2, amount of work to bring it to the top is
W=F.d
d=5m
But the force is not mg since there is water so net force must be less. But how much?
What are your thoughts?
I don’t know the law of baoency.
Then maybe a good place to start is looking that up? Archimedes’ principle is quite fundamental.
##F_b=-rhogV##
This is the formula of baouyant force which i think needs to be applied. But first of all what is this formula telling. There is no vector quantity in right side. So what is -ve doing here. Surely its to tell the sign of force.
The gravitational acceleration ##g## is technically a vector. The buoyancy formula tells you in math what Archimedes' principle says: The buoyancy is equal to the weight of the displaced liquid. (##\rho V## being its mass). Now, what is the mass of the displaced liquid if the object has mass 10 kg and relative density 2?
Orodruin said:
The gravitational acceleration g is technically a vector.
We always take -g in problems and that is a vector. Oh! you mean ##\vec F_b=-\rho V\vec g## where the value of ##\vec g=-g##. So the ##\vec F_b=F_b## in the upward direction.
Orodruin said:
The buoyancy is equal to the weight of the displaced liquid. (ρV being its mass).
Its obvious that the apparent weight of an object=weight of the object- buoyant force. But how is buoyant force equal to weight of water displaced?
We always take -g in problems and that is a vector. Oh! you mean F→b=−ρVg→ where the value of g→=−g. So the F→b=Fb in the upward direction.
No. ##g## is the magnitude of ##\vec g##. A magnitude can never be equal to a vector.
This is Archimedes’ principle. The actual proof requires a bit more math but you can argue for it for any column submerged in a fluid. Basically, assume a column submerged in a fluid and compute the pressure on top and bottom of the column.
On top zero
and on bottom mgh/V ,where V is the volume of water and h is height.
Orodruin said:
g is the magnitude of g→. A magnitude can never be equal to a vector.
I mean ##\vec F_b=-\rho V\vec g=>\vec F_b=\rho Vg##
which means Force of bouyancy should be upwards which it is.
On top zero
No, it is not necessarily zero at the top if the column is submerged.
No. The second equation makes absolutely no sense. The LHS is a vector and the RHS is a scalar.
##\vec F_b=+\rho Vg##
That is still equating a vector with a scalar. You simply cannot write things like that.
I have not studied the concept of fluid mechanics. So I don't think i can solve it without your help.
It is not about fluid mechanics, not equating a vector to a scalar is basic vector analysis.
Your first equation in #9 was correct for the buoyancy. After that it is up to you to use that to find the work required.
Ok. But to justify Fb is in upward direction we need to take the ##\vec g=-g##
Ok. But to justify Fb is in upward direction we need to take the vector g=-g
No. The minus sign in the correct equation already means that the buoyancy is in the opposite direction of the gravitational field. You can never equate a vector to a scalar. I believe what you are attempting is to resolve the buoyancy into its vertical component. The component of the gravitational field will depend on which direction you choose as positivebin your coordinate system.
is -g not a vector?
is -g not a vector?
No. Not if you want any sort of consistent notation and use ##\vec g## for the gravitational field.
Can we write it like this ##\vec F_b=-(-)\rho Vg##
The only way that g can equal -g is for g to be equal to 0.
is -g not a vector?
The point that @Orodruin repeatedly has been making, and that you aren't getting, is that g (a scalar, a number) and ##\vec g## (a vector) are different things. He is asking you to be consistent with vectors and notation. If the left side of an equation has a vector, the right side must have a vector as well.
No. This is exactly the same as ##\vec F_b = \rho Vg##
Again, you have a vector on the left side, but a scalar ( g ) on the right side. As written, the equation doesn't make sense.
No such word as "baoency".
Still not a word.
buoyant force
Closer, but the words are buoyant and buoyancy.
Mark44 said:
o. This is exactly the same as F→b=ρVg
I have always been putting in suvat eqns a=-g when calculating any of the s,u,v,a,t under gravity. Why is this different now. When doing problems on force and motion I always took -mg as downward weight. Why is this different now.
I believe you want ##\vec F_b=\rho Vg\hat j##
The suvat equations generally treat a single component of a vector relationship, not a vector relationship in itself. All of the involved quantities relate to that particular direction. If you want to express yourself in vectors then you meed to use vectors.
You also cannot blindly put a=-g in suvat either as it depends on how you defined your coordinates. If you define your coordinates with increasing coordinate downwards, it would be a=g.
Ok
Edit: I suppose ##F_b=\rho Vg## is correct if ##F_b## and ##g## are magnitudes.
I suppose ##F_b=-\rho Vg## is also correct
I suppose ##F_b\hat j =-\rho Vg\hat j ## is same as second one
I suppose ##\vec F_b=-\rho V \vec g## is also correct.
These three eqns above are saying the same thing that ##F_b##=##\rho Vg## and there directions are opposite to each other.
I suppose ##\vec F_b=\rho Vg## is wrong. We need to define ##\vec g=-g\hat j## and put in ##\vec F_b=-\rho V \vec g##
then it becomes ##\vec F_b=\rho Vg\hat j##
I suppose Fb=−ρVg is also correct if Fb and g are vectors.
This is a scalar equation that is one of the components of the correct vector equation, not a vector equation. Its correctness depends on how you defined your coordinate directions.
I suppose F→b=−ρVg→ is same as second one.
No. Definitely not. One is a relation between two vectors, the other is a relation between two scalars.
We need to define g→=−gj^
You do not define this. You can pick your coordinate axes such that it is the case however.
I defined F_b and g as vectors but if I am wrong please show me what do you mean.
Then your notation is wrong. If you are using vector notation, you need to do it consistently.
It's best to use a scalar equation for Archimedes principle with the understanding that the buoyant force acts in an upward direction. That way things are kept simple and one can start applying it to problem at hand without unecessary confusion.
So, I would just use the following formula: ##F_b = \rho V g##, where all quantities are positive. ##V## is volume of fluid displaced by the submerged body and ##\rho## is density of fluid. And of course ##g## is acceleration due to gravity.
I think you miss understood me. I am trying to write different variations of the same law (law of buoyancy)in vector and magnitude form. It’s not a question about consistency.
I am trying to write correctly and avoid making mistakes with signs which I often make.
If you are trying to avoid making such mistakes then you really need to make sure your notation is on point. You cannot ramdomly assign g to be a vector in some expressions and a vector magnitude in others and on top of everything also introduce ##\vec g##. I am not surprised you make sign errors with such inconsistency in notation.
  • · Replies 39 ·
  • · Replies 97 ·
14K
