A tricky 2nd Oder ODE Problem,nonhomo delta=0 case
  • Context: Graduate
  • Thread starter Thread starter whatababy
    Ode
The discussion focuses on solving the initial value problem for the second-order non-homogeneous ordinary differential equation (ODE) given by y'' + 8.4y' + 17.64y = e^(-4.2x) with initial conditions y(0) = 1 and y'(0) = 1. The correct approach involves first solving the homogeneous equation, yielding the complementary solution yc = c1e^(-4.2x) + c2xe^(-4.2x). To find the particular solution, the assumption yp = Ax^2e^(-4.2x) is necessary due to the overlap with the homogeneous solutions. The final solution is derived correctly after addressing differentiation errors.
  • Understanding of second-order ordinary differential equations (ODEs)
  • Familiarity with the method of undetermined coefficients
  • Knowledge of homogeneous and non-homogeneous equations
  • Proficiency in differentiation of exponential functions
  • Study the method of undetermined coefficients in-depth
  • Explore the theory of linear differential equations
  • Learn about the Wronskian and its application in solving ODEs
  • Practice solving initial value problems with varying coefficients
Students and professionals in mathematics, particularly those focusing on differential equations, as well as educators seeking to enhance their teaching methods in this area.
whatababy
solve the initial value problem:
y''+8.4y'+17.64y=e-4.2x
y(0)=1, y'(0)=1
y(x)=?
The way I tried to achieve is to solve the corresponding homo equation first:
y''+8.4y'+17.64y=0, which gives yc;
yc=c1e-4.2x+c2e-4.2xx
Then try to find yp, generally I would assume a yp=Ae-4.2x, but from the yc got above, clearly yp=Ae-4.2x or yp=Ae-4.2xx is not good. If I add one more 'x' in yp assumption,in which it seems A has to be 0, which is not right either...
Any idea? Or I made some mistake?
Meric.
Because both e^{-4.2x} and xe^{-4.2x} satisfy the homogeneous equation, you need "go up" one more x: try
y_p= x^2e^{-4.2x}
Was that what you meant by "add one more 'x' in yp assumption"?
If
y_p= Ax^2e^{-4.2x}
then
y_p'= 2Axe^{-4.2x}- 4.2Ax^2e^{-4.2x}
and
y_p"= 2Ae^{-4.2x}- 16.8Axe^{-4.2x}+ 17.64Ax^2e^{-4.2x}
Putting that into the differential equation, all the terms involving xe^{-4.2x} or x^2e^{-4.2x} will cancel leaving only 2Ae^{-4.2}= e^{-4.2x} so A is NOT 0.
Oh I made a silly mistake in differentiate the Yp...
Yeah, you are right, I got the right answer now. Thanks
