Is Charge Conserved in Electromagnetic Interactions Between Particles?
The discussion centers on the conservation of charge in electromagnetic interactions between charged particles, emphasizing the role of the unitary operator U in quantum mechanics and quantum field theory (QFT). The Noether theorem is highlighted as a foundational principle linking symmetries and conservation laws, specifically in the context of U(1) symmetry associated with charge conservation. The participants explore the nature of the operator U, its implications for observables, and the distinction between continuous and discrete transformations. The conversation concludes with a clarification of U(1) invariance in relation to wavefunctions and dynamical variables.
  • Noether theorem in physics
  • Quantum mechanics (QM) fundamentals
  • Quantum field theory (QFT) principles
  • Unitary operators in Hilbert space
  • Study the implications of Noether theorem on conservation laws in physics
  • Explore U(1) symmetry in quantum field theory
  • Investigate the role of unitary operators in quantum mechanics
  • Examine the differences between continuous and discrete symmetries in quantum systems
Physicists, particularly those specializing in quantum mechanics and quantum field theory, as well as students seeking to understand the relationship between symmetries and conservation laws in electromagnetic interactions.
Clear Mind
Suppose you have two charged particles that interact by e.m. potential ##V(\vec{r_1},\vec{r_2})##, the total charge is conserved. Since there's a conserved quantity, it must exist a transformation for which the hamiltonian is invariant (Noether theorem). Let's be the operator ##U## ##(U^{\dagger}=U^{-1})## the generator of the aforementioned trasformation, you have that:
##H'=U^{\dagger}HU##
and
##H'=H##
so that
##[H,U]=0##
Now the questions are:
What is ##U##?
Is ##U## a continuous or discrete transformation?
Is ##U## an observable (##U=U^{\dagger}##)?
Don't know if such a thing exists in NRQM.
But in QFT charge conservation comes from a U(1) symmetry of the field.
and
##H'=H##
so that
##[H,U]=0##
What is ##U##?
Unitary operator on Hilbert space, see next post.
Well you mentioned Noether theorem! Does Noether theorem applies to discrete symmetry?
See the next post.
You can treat QM as non-relativistic field theory and apply Noether theorem. Indeed, the Schrödinger equations for \Psi and \Psi^{ \dagger } are the Euler-Lagrange equations of the following Lagrangian \mathcal{ L } = \frac{ \hbar }{ i } ( \Psi^{ \dagger } \partial_{ t } \Psi - \Psi \partial_{ t } \Psi^{ \dagger } ) + \frac{ \hbar^{ 2 } }{ 2 m } \nabla \Psi^{ \dagger } \cdot \nabla \Psi + V ( r ) \Psi^{ \dagger } \Psi . This Lagrangian is invariant under U(1) phase transformation, i.e. \delta \mathcal{ L } = 0 , \ \ \mbox{ when } , \ \ \delta \Psi = i \alpha \Psi , \ \delta \Psi^{ \dagger } = - i \alpha \Psi^{ \dagger } . Now do the algebra and you will find (when the fields satisfy the E-L equation) the following continuity equation \partial_{ t } \left( \frac{ \partial \mathcal{ L } }{ \partial ( \partial_{ t } \Psi ) } \delta \Psi + C.C \right) = \nabla \cdot \left( \frac{ \partial \mathcal{ L } }{ \partial ( \nabla \Psi ) } \delta \Psi + C.C \right) . This is nothing but the familiar QM equation \partial_{ t } ( \Psi^{ \dagger } \Psi ) = - \frac{ \hbar }{ 2 m i } \nabla \cdot ( \Psi^{ \dagger } \nabla \Psi - \Psi \nabla \Psi^{ \dagger } ) . Integrating this over the whole volume of the field and using the divergence theorem, we find the following conserved charge (operator) \frac{ d Q }{ d t} = \frac{ d }{ d t } \int d^{ 3 } x \ \Psi^{ \dagger } ( x ) \ \Psi ( x ) = 0 . You can show that [ Q , H ] = 0 and that the unitary operator U( \alpha ) = \exp ( i \alpha Q ) generates the correct transformations on the fields through \delta \Psi ( x ) = [ i \alpha Q , \Psi ( x ) ] .
Sam
Thank you very much for the help!
Professor told me that Noether theorem does not apply to discrete transformation (like parity), he told this 100 times, but i continue to forget every time! My apologies
Sam
That's still a whole different affair though. I mean U(1) invariance of the position state representation is not at all the same as U(1) invariance of the dynamical variable itself.
First of all, the “position state representation” i.e. the wavefunction IS NOT invariant under U(1)-transformation. Second, under U(1), \Psi (x) (whether it is regarded as a wavefunction or dynamical field variable) transforms according to \Psi ( x ) \to e^{ i \alpha} \Psi ( x ) . Infinitesimally, we write this as \delta \Psi ( x ) = i \alpha \Psi ( x ) .
I think it's fairly obvious that by U(1) invariance I meant invariance of the lagrangian.
Right, you still need to tell us what exactly you meant by
"I mean U(1) invariance of the position state representation is not at all the same as U(1) invariance of the dynamical variable itself."
  • · Replies 0 ·
