About lift equation -- Trying to build a miniature helicopter
  • Thread starter Thread starter daraphy
    Aerodynamics
The discussion revolves around the application of the lift equation in the context of building a miniature helicopter. Participants explore the validity of using the lift equation with specific parameters, such as coefficient of lift, air density, velocity, and wing area, while considering the differences between wings and propellers.
  • One participant calculates a lift of 12.25 N per wing using the lift equation and questions if this means three wings can lift around 5 kg.
  • Another participant points out that a propeller is not a wing, noting that air velocity varies with radius and questioning if this has been considered.
  • Some participants express confusion about the angle of attack and its implications for lift, suggesting a need for further understanding of propeller aerodynamics.
  • A participant emphasizes the importance of considering the twisted profile of blades and the varying lift along the length of the blade due to different tangential velocities.
  • There are references to external resources for further reading on aerodynamics and helicopter design.
  • One participant mentions the need to work with units correctly and highlights the assumptions inherent in the lift equation, particularly regarding uniform velocity and undisturbed air.
Participants do not reach a consensus on the application of the lift equation to propeller design. There are multiple competing views regarding the assumptions made in the calculations and the differences between wings and propellers.
Limitations include assumptions about uniform velocity across the wing area, the applicability of the lift equation to propellers, and the effects of blade design on lift generation.
daraphy
TL;DR
Lift Equation gives me 12.25 Newtons per wing. Am I using it right?
Saw this equation on Nasa's website about lift equation:
I'm trying to build a miniature helicopter and decided to test that equation.
For CI I used 0.5 because I saw a graph where flat air foils gets 0.5 CI when placed at around 10 degrees.
For air density I went with 1.225 because I live near sea levels.
For Velocity I used 20m/s and for A I used 0.1 m^2.
0.5 * 1.225 * (20^2)/2 * 0.1 = 12.25 N (I'm guessing the output is in newtons)
If multiplied by 4 wings, it gives 49N. Divided by gravity, around 5Kg.
Am I doing this right? Does that mean 3 0.1m^2 wings can lift around 5Kg?
daraphy said:
TL;DR Summary: Lift Equation gives me 12.25 Newtons per wing. Am I using it right?
I'm not going to be of much help except to ask for clarification on the velocity number. A propeller is not a wing. The air velocity varies with radius, and the angle of the "wing" for a propeller usually varies with radius because of this. Are you taking this into account?
Did you read the Nasa tutorial?
I converted the RPM's of my motor to m/s using 0.1 as the radius. I did not understand the angle part
I dont see any tutorial at the page
You haven't yet looked at the aerodynamics of propellers and their shapes?
I saw a flat air foil can do the work so I sticked with that
https://www.grc.nasa.gov/www/k-12/VirtualAero/BottleRocket/airplane/lifteq.html
Do you only want to build a miniature helicopter, or to learn about aerodynamics in general, or both?
Building a sufficiently light and controllable RC helicopter is very difficult.
Regarding design, I would like you to consider the following:
Three blades of ##0.1 m^2## will make the span of the rotor to be around 2 meters, which will require a very powerful engine to make the tips of the blades to spin at ##20 m/s## (at 190 rpm).
All the weight is going to be hanging from the blades, reason for which their cross section must be robust and thick, which makes your flat blade a poor choice.
That tangential velocity (and associate lift) will decrease to close to zero as you move towards the root of the blade.
Consider that the NASA simulator is for a wing of infinite span, which does not suffer the tip vortices of a real wing that decrease the lift.
Also, the maximum lift is achieved around 10° of angle of attack.
The wing or blade will stall and loose most of the lift if that angle increases.
Therefore, the root of your blade can have that maximum angle, but it must decrease as moving towards the tip, reason for which your blade should have a twisted profile.
Because of that, you will not be able to have the values of max velocity and max angle of attack and max CL that you have input into your equation for all the sections of your blade.
Root of the blade: Lift is associate to slowest tangential velocity and maximum CL or AOA.
Tip of the blade: Lift is associate to fastest tangential velocity and small CL or AOA.
Please, visit this website for discussions and debates on designing, building an dflying successful miniature RC helicopters:
https://www.rcgroups.com/aircraft-fuel-helis-39/
https://www.rcgroups.com/aircraft-electric-helis-217/
https://www.rcgroups.com/aircraft-misc-130/
thx for the info ill check the websites to :)
You don't need to guess the units of the answer, you need to work with units.
##F = CI \rho \frac{v^2}{2} A = 0.5 \frac{1.225 kg}{m^3} \frac{(20 m/s)^2}{2} 0.1 m^2 = 12.25 kg \frac{m}{s^2} = 12.25 N##
This formula is assuming all of the wing has the same velocity relative to the air. Your helicopter blades won't. Most of the lift will come from the area near the end, while the slower parts in the center will provide less lift. The formula also assumes a single wing that goes through undisturbed air, which isn't necessarily the case for your helicopter.
You cannot have an area of 0.1 m^2 with a radius of 0.1 m.
  • · Replies 30 ·
17K
14K
11K
