About the premises behind the Schrödinger equations
  • Context: Undergrad
  • Thread starter Thread starter snoopies622
    Schrödinger
The discussion revolves around the premises and derivation of the Schrödinger equations, exploring whether they can be derived from fundamental assumptions and the implications of such derivations. Participants examine the relationship between classical mechanics and quantum mechanics, as well as the historical context of Schrödinger's original formulation.
  • Historical
  • One participant suggests that the Schrödinger equations can be derived from specific physical assumptions, including equations related to wavefunctions and energy, but notes inconsistencies with their general application.
  • Another participant counters that the derivation presented is limited to free particles with fixed momentum, indicating that the Schrödinger equation is more general than the assumptions made.
  • A participant elaborates on the derivation process, showing how starting with a specific wavefunction leads to the general forms of the Schrödinger equations.
  • Some participants express skepticism about the claim that the Schrödinger equations cannot be derived, referencing the possibility of deriving them from quantum field theory as a non-relativistic limit.
  • There is mention of Schrödinger's original approach being an "inspired guess," drawing analogies between classical mechanics and wave optics, which some participants find intriguing.
  • Another participant discusses the philosophical implications of deriving quantum theory, emphasizing the non-classical nature of quantum mechanics and the linearity of the wavefunction.
  • One participant references historical errors made by Schrödinger in his derivation process, suggesting that these errors were significant yet ultimately canceled each other out.
Participants express differing views on the derivability of the Schrödinger equations, with some asserting that they can be derived under certain conditions while others maintain that the equations are fundamentally distinct from classical mechanics. The discussion remains unresolved regarding the implications of these derivations and the historical context of Schrödinger's work.
Participants note that the assumptions made in the derivation may not fully align with the general use of the Schrödinger equations, highlighting limitations in the derivation process and the historical context of Schrödinger's original formulation.
snoopies622
Long ago I read on these forums that one cannot derive the Schrödinger equations because they're fundamental scientific laws. But I have noticed that I can generate them by making the following physical assumptions and then doing a trivial amount of substitution and differentiation:
(1) [tex]\frac {\partial ^2 \psi }{\partial x^2} + k^2 \psi = 0[/tex]
(2) [itex]\lambda = h/p[/itex]
(3) Total energy = PE + [itex]p^2/2m[/itex]
and (4) [itex]E=h \nu[/itex]
where (4) is only needed for the time dependent form.
What bothers me is that (1) assumes a [itex]\psi[/itex] with a definite wavelength — that is — a momentum eigenfunction, and (4) was arrived at for photons, and of course the S.E.'s are used to deal with wavefunctions that are not necessarily momentum eigenfunctions and for particles that are not photons.
Thoughts?
You derived the Schrödinger equation limited to free particles with fixed momentum. It turns out that the equation is more general than that.
I did not derive it at all here, I'm saying that putting (1),(2) and (3) together it is easy to arrive at
[tex] \frac {\partial ^2 \phi} {\partial x ^2} + \frac {8 \pi ^2 m }{h^2}(E - PE) = 0[/tex]
and then adding (4) we can get
[tex]i \hbar \frac {\partial \phi} {\partial t } = E \phi[/tex]
and these forms are not limited to momentum eigenfunctions, nor are they for photons, yet (1) and (4) are connected to those physical premises.
In case you're wondering, I'll show you explicitly what I mean in an upcoming post.
What I had in mind was . . if we start with
[tex] \phi = \phi_0 e^{i(kx-\omega t)}<br /> [/tex]
and take the derivative with respect to x twice and rearrange terms, we get (1) in the original post.
Then if we plug in [itex]k=2 \pi / \lambda[/itex] , [itex]\lambda = h/p[/itex], [itex]KE = p^2 /2m[/itex] and E = KE + PE, we get the time independent form I cited in entry #3 above.
If instead we start with
and take the time derivative once, then substitute [itex]\omega = 2 \pi f[/itex], f=E/h, [itex]\hbar = h/ 2 \pi[/itex] and rearrange terms, we get the time dependent form I cited in entry #3 above.
Thus we start with a [itex]\psi[/itex] with a definite wavelength and definite speed and yet end up with the general (one dimensional) Schrödinger equations.
Bumping an old thread from a couple months ago, hope y'all don't mind. I've given this matter more thought but still find it odd that one can produce the Schrödinger equations by making assumptions that are not entirely consistent with their general use. How did Schrödinger himself arrive at them? I have not seen his original paper.
Can you give a specific link to a post? This claim seems highly dubious to me since AFAIK it is perfectly possible to derive the Schrödinger equation as a non-relativistic limit of an appropriate quantum field theory, and in any case the Schrödinger equation, being non-relativistic, is obviously an approximation only.
Read this:
http://www.pnas.org/content/pnas/110/14/5374.full.pdf
Zz.
Thanks all. "Inspired guess" is what I figured. The mechanics-optics connection reminds me of something I read many years ago in a book on the history of physics — that had Hamilton lived long enough, he himself would have invented quantum mechanics.
If you wish to derive quantum theory as Schrödinger did, there is really only two fundamental assumptions ( with the addition that you would need to derive S-equations for each class of Hamiltonian).
1) Quantum theory is not classical, that is, the Hamilton-Jacobi equation is not true. A scalar, that measures "nonclassicality" for all the spacetime, can be introduced. The quantum theory is different then all other theories, that is, the scalar has an extrema (typically a minimum). This is philosophically the same as the principle of least action.
2) The theory that guides the "wavefunction" must be linear. The wavefunction is introduced intuitively, through the action.
Linearity is a very strong limitation, and with a correct choice of Hamiltonian, you can get back the S-equation with some variational calculus.
Read chapter 3 Ballentine.
Like so much of physics its real basis is symmetry - but you must read what I mentioned, then think. BTW Wigner got a Nobel for figuring it all out.
Thanks
Bill
For the detail see:
https://arxiv.org/pdf/1204.0653.pdf
He even made two errors that canceled each other out: Schrödinger’s notes [49] show that he was well aware that the solution of (8.12) gives correctly the bound state energies of the hydrogen atom before introducing in the anstaz concerning the hypothetical quantity J. This artifice compensates for the physically incorrect ansatz. The constant K should actually be the pure imaginary quantity −ih in which case (8.5) becomes the correct equation (7.27). Repeating Schrödinger’s stationary algorithm starting with the correct relation S = −ih¯ ln ψ would then give the incorrect equation (8.5)! Indeed, since the H-J equation and the properties of the generating function S already follow from Hamilton’s equations which in turn are a consequence of Hamilton’s Principle the condition that the action S should be stationary for arbitrary variations of space-time path it would seem that Schrödinger is attempting here to close a door that is already shut
Thanks
Bill
  • · Replies 17 ·
  • · Replies 31 ·
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 31 ·
