olgerm
- 41
Suppose one photon goes through an interferometer and then hits a screen. A device detects the hit position, digitizes it, and later a person Bob reads the output.
So before detection, ##\Psi## describes one coherent quantum process.
where each component ##\Psi_i## corresponds to the photon having triggered the screen near position x_i.
At this stage, the different components of the wavefunction become entangled with many microscopic degrees of freedom of the screen and the environment. Because of this, the components ##\Psi_i## rapidly decohere.
So after the hit, the total wavefunction is a superposition of many decoherent branches, each branch corresponding to amplification beginning at a different screen location. (remember that in real world decorence is just approximate and these really do interact, but the interaction is too small to be mesured)
where each branch corresponds to the device displaying a different coordinate ##x_i##.
Because the branches are decohered, they no longer interfere with each other (remember that in real world decorence is just approximate and these really do interact, but the interaction is too small to be mesured). just like light from 2 different lights-bulbs can not form inteference pattern with eachother.
##\Psi \approx \sum_i (c_i \Psi_i^{(\text{Bob sees }x_i)})##
Each branch now contains:
A Bob in one branch cannot access or communicate with the Bobs in the other branches, because the branches are decohered and evolve independently. (remember that in real world decorence is just approximate and these really do interact, but the interaction is too small to be mesured). For exmple Bob in branch where device output coordinate=0.3248198481 can not know about Bob in Branch where device outputs coordinate=0.6184932771 nor know how this Bob in this branch reacted. If Bob in some branch of ##\Psi## told his output to some other person then this person would also be in the same Branch as the Bob who told him this. there would be as many branches as there is possibles outputs of the digitalizing device. experiment could be made so that weight of any branch is smaller than sum of weight of other branches. This digitalizing device is similar to Schrödinger cat (makes entageled states to correspond to decoherent macroscopic states), but it enables many different outputs(depending on number of digits in digitalizing device) instead of boolean output(cat dead or alive).
##\Psi## is one continuous function that takes system-configuration at given time as argument. system-configuration is list of elementary particle coordinates at give time or field-state at given time.And after decoherence it can be written approximately as a sum of almost non-overlapping components(branches). After interaction with the screen and environment, the total wavefunction can be approximately decomposed into a sum of decohered components(branches). Branch component is a continuous wave packet concentrated on a macroscopically distinct region of configuration space (or field-configuration space), corresponding to a different detector outcome.
Interesting question is wether Bob(or any other person in similar experiment setup that can be made in real life) would be councious or there is only some special branch only which there is counciosnes? Or would the Bob's subjective experiences were somehow more vivid in braches that have bigger amplitude? in everyday life the ##\Psi## all the time branches and there are more and more braches that do not remerge.
This is thread branched from thread https://www.physicsforums.com/threa...antum-and-consciousness.1082604/#post-7307172 .
1. Before detection
Initially the total wavefunction ##\Psi## describes:- the photon moving toward the interferometer,
- the screen in its ready state,
- the detector electronics in their ready state,
- Bob in his ready state.
2. After the photon lands on the screen
When the photon interacts with the screen, the total wavefunction becomes approximately ## \Psi \approx \sum_i(c_i*\Psi_i) ##where each component ##\Psi_i## corresponds to the photon having triggered the screen near position x_i.
3. After the device has digitized the coordinate
The detector electronics amplify the local event and convert it into a digital output. The total wavefunction now has the approximate form ##\Psi \approx \sum_i (c_i \Psi_i^{(\text{device outputs }x_i)})##where each branch corresponds to the device displaying a different coordinate ##x_i##.
4. After Bob reads the device
When Bob looks at the device, he becomes entangled with the detector state. The total wavefunction becomes approximately##\Psi \approx \sum_i (c_i \Psi_i^{(\text{Bob sees }x_i)})##
- a screen hit near ##x_i##,
- a detector output equal to ##x_i##,
- a Bob who sees and reports the coordinate ##x_i##.
