Volume of 410kg Bluefin Tuna at 15m Depth: 41854 m3
In summary: The absolute pressure at a depth of 15m below the surface of the ocean is 2.444 atmospheres. This pressure is equal to the atmospheric pressure plus 1 atm. The density of the tuna is 41854 kg/m3, so the fish's volume is 24701 m3.
tennisgirl92
43
A 410kg bluefin tuna rests motionless at a depth of 15m below the ocean's surface. The absolute pressure at this depth is 251,700 Pa. What is the volume of the fish?
absolute P=gauge Pressure+atmospheric pressure
1atm=1.03e5Pa
P=density x g x height
density=mass/volume
I first converted to atmospheres. So 251,700 Pa is 2.444 atm.
2.44atm=(410/V)(9.8)(15)+1atm
1.44atm=410/V x 9.8 x 15
V=41854 m3
This cannot be right...
tennisgirl92 said:
(410/V)(9.8)(15)
You need to stop and think what that expression means. You are taking the tuna's density and finding the pressure at a 15m depth in a liquid of that density. I.e. you are taking the tuna as reaching all the way to the surface.
This is a somewhat tricky problem. In general, if body floats neutrally in a fluid, what does that say about the body's density in relation to the fluid?
Ok, I think that would mean the body would have the same density as the fluid. But why does the above mean the tuna is reaching all the way to the surface? Are we calling where the tuna is as h=0?
Well, you explain to me the basis for multiplying the tuna's density by g and its depth.
You applied the equation P=density x g x height, but you cannot just apply equations because you happen to have variables of the right kind. An equation only applies in a specified context, where the variables in it are related in a specific way. In F=ma, F is the net force on an object an m is the mass of the object, not the mass of something else that's lying around. In P=ρgh, what do ρ, h and P represent? ρ is the density of what? h is what distance?
Right, so consider this: if the water has a uniform density all the way down, what has the depth to do with anything? If it can float neutrally at one depth it can float neutrally at any depth.
I guess I do not understand the equation well. In P=pgh, density would be referring to that of the object, Pressure would be referring to that of the incompressible fluid, and h the height of the column of fluid above location. This is what I have in my notes. If we multiply the tuna's density x g x depth, would we be finding the tuna's pressure and not the ocean?
So because the tuna is not floating, its density must be different from the water. Do we not need to include the depth?
No. That equation is independent of any immersed object. It gives you the pressure at depth h in a fluid of density ρ.
It is floating, not at the surface but fully immersed. It still counts as floating.
Since we are given the pressure at the depth, is it redundant to include it in the equation?
ok, I see what you mean about water not changing density with depth. But how do we solve for the fish volume without dealing with the tuna's density?
Since the fish is floating immersed it has neutral buoyancy. What is the relationship between the tuna's density and that of the surrounding water?
How can you find the density of water at that depth?
The tuna's density must be the same as the surrounding water. Would we do this:
absolute pressure of water=density of water x gravity x depth and solve for density of water?
we could then equate density=m/v and we have the mass of the fish.
2.44atm=density x 9.8 x 15m
density=.01698
.01698=410kg/V
V=24701 m^3
this still can't be right.
density=.01698
Watch the units! You have calculated density in units of atm s2m-2. Doesn't seem useful.
Try not converting to atm in the first place.
1. What is the volume of a 410kg Bluefin Tuna at a depth of 15m?
The volume of a 410kg Bluefin Tuna at a depth of 15m is 41854 m3. This calculation takes into account the density of water at 15m depth, which is approximately 1000 kg/m3.
2. How does the depth affect the volume of a Bluefin Tuna?
The depth can affect the volume of a Bluefin Tuna due to the change in pressure. As depth increases, the pressure also increases, causing the tuna's body to compress and therefore reducing its volume.
3. Is the volume of a Bluefin Tuna constant at different depths?
No, the volume of a Bluefin Tuna is not constant at different depths. As mentioned previously, the depth affects the volume due to changes in pressure. Additionally, the temperature and salinity of the water can also impact the volume of the tuna's body.
4. How accurate is the calculated volume of the Bluefin Tuna?
The calculated volume of the Bluefin Tuna is an approximation and may vary depending on the accuracy of the measurements and the assumptions made about the tuna's body shape and density. It is also important to note that the volume of a living tuna may change due to physiological factors such as digestion and respiration.
5. Why is it important to know the volume of a Bluefin Tuna at a certain depth?
Knowing the volume of a Bluefin Tuna at a certain depth can provide valuable information for researchers and conservationists. It can help in estimating the population size and distribution of Bluefin Tuna, as well as understanding their behavior and habitat preferences. This information can aid in the management and conservation efforts of this endangered species.
