Absolute Uncertainty - Enough Information?
The discussion revolves around determining the absolute uncertainty of a mass reading from an electronic scale that shows 502.4 g. Participants express frustration over the lack of information provided in the question, particularly the absence of a label indicating the scale's precision. A consensus emerges that the uncertainty can be estimated as ±0.05 g, based on the assumption that the scale rounds to the nearest tenth. The conversation highlights the importance of significant figures and the need for clarity in measurement questions. Ultimately, the uncertainty is concluded to be ±0.05 g, reflecting the limitations of the given data.
aborder
If an electronic scale reads 502.4 g, what is the absolute uncertainty in the mass reading.
Not sure
Not a clue, it seems that there isn't enough information given. How am I supposed to figure out the absolute uncertainty if this is all that is given?
It should have a label on the scale.
That's funny because I was thinking the same thing. Unfortunately it is straight out of a textbook so nothing is given other than the question itself. Not sure how to approach this one. Any ideas?
My first thought is to consider significant figures. If you were given a value of 10, would you think it's reasonable to have an uncertainty of +/- 0.1? Probably not, because the output you have is not given to any decimal places. So in this case where we have 502.4g we should ask how exact can we get before we reach the limit of the measurement.
-Eric
-Eric
So then are we saying with absolute certainty that the measurement is 502.4g since no other information is given? Therefore, the uncertainty would be +/- 0.0. Obviously if we were given 502.2 - 502.6 we would know the uncertainty to be +/- 0.2.
It's a lousy question and your text should be burned in an effort to the improvement the human condition.
However
It seems we are supposed to assume the measuring electronics deliver 100% accuracy to the display.
If the actual mass were 502.351 g what would the meter read?
If the actual mass were 502.449 g what would the meter read?
Not sure
I think all figure are taken as =- 1/2 of the last digit - unless stated as bigger.
So 502.4 =-0.05
However
I suppose that it would read 502.4 because it rounds to the nearest tenth. I guess we assume that when only the tenths place is given. The thing is, how do I know what to assume when this isn't discussed in the text.
Yah, fire always brings me comfort. Especially when it involves burning something that is persecuting me.
So 502.4 =-0.05
Wouldn't it also be + 0.05 as well if the meter rounds to the nearest tenth? I guess we really don't know since there isn't any additional information provided.
Look at the keyboard ... I was too brief with the shift key so got = instead of +
Given that I've correctly read between the lines of your text, what do you get for the absolute error?
phrak said:
given that I've correctly read between the lines of your text, what do you get for the absolute error?
502.4 +/- 0.05
Excellent, thank you.
That's a good trick. How do you typo "+/-" into "="? The fingers must by flying.
Not quite, the typo was "=-" instead of "+-"
  • · Replies 21 ·
  • · Replies 16 ·
