Absolute value and differentiability
8 replies · 2K views
Niles
Hi all
I have f(x)=|x|. This I write as
f(x) = -x for x<0
f(x) = x for x>0
f(x) = 0 for x=0
If I want to show that f(x) is not differentiable at x=0, then is it enough to show that
f'(x) = -1 for x<0
f'(x) = 1 for x>0
and from this conclude that it is not differentiable at x=0? I am a little worried about f(x) at x=0.
You're close, but those two statements about f'(x) really only tell you about the derivative at points other than x=0. You need to address f'(0) explicitly and say why it doesn't exist. By definition, you have that
[tex]f'(0) = \lim_{h \rightarrow 0} \frac{f(h)-f(0)}{h}[/tex]
What are the requirements for this limit to exist?
That the limit is the same when approaching it from both sides?
So if I write what I wrote in my OP and add that f'(0) does not exist because it is not the same when going to 0+ and 0-, then f'(0) is not defined?
Hi Niles! :smile:
As vela :smile: has indicated, you're missing the point …
you don't need to use results related to one-sided differentials (and you'd have to state those results, and prove that they give you the answer you want, which would be very roudn-about) …
just use the definition of f'(0) (choose a delta, and describe what happens :wink:).
Uhm, I'm a little confused now. I understand that my mission is to show that f'(0) does not exist.
I can show that it isn't continuous (is that what you mean when you say choose a delta?), but differentiability => continuity, so showing that it is not continuous won't help me that much :confused:
You're making this too complicated …
forget f'(x), just use (f(x+h)-f(x))/h …
[STRIKE]describe how (f(x+h)-f(x))/h behaves around x= 0, and show that that means that it has no limit.[/STRIKE]
describe how (f(h)-f(0))/h behaves around h = 0, and show that that means that it has no limit. :smile:
For x<0 it is -1, and for x>0 it is 1, but I am not sure this is what you are referring to?
No, it does not, so it's not differentiable there. Thanks!
