Absolute value in solution to separable differential equation
  • Thread starter john.lee
john.lee
y'=-5xy, y=?
i solved that,
dy/dx=-5xy
dy/y=-5x dx
∫(1/y)dy=∫-5x dx
= ln(lyl)= -2.5x^2+C
so, y=+- e^(-2.5x^2+C)
=+-K*e^(-2.5x^2)
but the answer is y=K*e^(-2.5x^2)
how can i understand this?
just shoud i ignore "the absolute value"?
john.lee said:
y'=-5xy, y=?
i solved that,
dy/dx=-5xy
dy/y=-5x dx
∫(1/y)dy=∫-5x dx
=+-K*e^(-2.5x^2)
In your solution ##K = \pm e^C## which can be anything but zero. In the answer ##K## is unrestricted. So the only difference is that the answer includes ##y=0## and your solution doesn't. (It was missed when you divided by ##y##). The answers are the same once you include ##y=0## in yours.
Yep.
The only reason |abs| is used is to mark the fact that it's impossible to have a ln() value where the thing in the brackets is negative.
Essentially y must be positive for the equation to work.
The only time I can think of that you really need to use +/- is when you have a value with an even power, such as x2, x4, x-6, etc. Because then x can be positive or negative and will still yield the same result when you raise it to that power.
Hope that helps a little!
