Abstract Algebra First Isomorphsm Theorem
The discussion revolves around the application of the First Isomorphism Theorem in abstract algebra, specifically focusing on the isomorphism between the quotient ring Q[x]/(x^2-3) and the set of numbers of the form {a+b*sqrt(3)}. Participants are exploring the necessary homomorphism and kernel related to this theorem.
  • Participants discuss the need to establish a homomorphism from Q[x] to {a+b*sqrt(3)} and question how to define this mapping, particularly for the polynomial x^2-3. There is an exploration of how to generalize the mapping and the implications of the kernel containing 0.
The discussion is active, with participants offering insights into defining the homomorphism and addressing concerns about the kernel. There is recognition of the challenges in proving that the proposed mapping is indeed a homomorphism, and some participants suggest specific calculations to aid in this proof.
There is a correction regarding the polynomial involved, changing from x^3-3 to x^2-3, which may affect the discussion on the homomorphism and kernel. Participants are also considering the implications of including 0 in the kernel as part of the First Isomorphism Theorem.
CurtBuck
Use the First Isomorphism Theorem to show that Q[x]/(x^3-3) is isomorphic to {a+b*sqrt(3)}
First Isomorphism Theorem:
If f: G-> H is a homomorphism then G/ker(f) is isomorphic to im(f)
I understand that I need to show that Q[x] is homomorphic to {a+b*sqrt(3)} with a kernel of x^3-3. I am really struggling in finding that homomorphism. I see the connection between sqrt(3) and x^3-3, e.g. sqrt(3) is a root of x^3-3, but I don't understand how this helps.
It is clear that you should choose f(q)=q, for every [tex]q\in \mathbb{Q}[/tex]. So you only need to know what f(x) is. What you certainly want is [tex]f(x^3-3)=0[/tex]. Using that f should be a homomorphism yields that [tex]f(x)^3-3=0[/tex]. So what should be f(x)?
First, I apologize, I meant to right that the polynomial being modded out of Q[x] is x^2 - 3, not x^3 - 3.
So that being said, I understand that f(x)^2 - 3 = 0 implies that f(x) = sqrt(3).
But then how would one generalize this?
Well, f(q)=q for [tex]q\in \mathbb{Q}[/tex] and [tex]f(x)=\sqrt{3}[/tex].
So [tex]f(a+bx)=a+b\sqrt{3}[/tex] and [tex]f(a+bx+cx^2)=a+b\sqrt{3}+c\sqrt{3}^2=a+3c+b\sqrt{3}[/tex]. Now try to generalize what I'm doing here...
I understand what you're doing there.
Two more things:
How do I prove that this a homomorphism?
Also, wouldn't 0 also be in the kernel? Is this allowed for the First Isomorphism Theorem?
Hmm, showing that this is a homomorphism is indeed not so easy.
First take a general polymial and calculate
[tex]f\left(\sum_{k=0}^n{a_kx^k}\right)[/tex]
This will help you. Then with this information, you only need to calculate
[tex]f\left(\sum_{k=0}^n{a_kx^k}+\sum_{k=0}^n{b_kx^k}\right)[/tex]
and
[tex]f\left(\sum_{k=0}^n{a_kx^k}\sum_{k=0}^n{b_kx^k}\right)[/tex].
As for the other question. Of course 0 is going to be in our kernel, and this is not a problem. The first isomorphism theorem requires us that the kernel equals [tex](x^2-3)[/tex], that is: the ideal generated by [tex]x^2-3[/tex]. And 0 is in this ideal...
To show that "evaluation at [tex]\sqrt{3}[/tex]" is a homomorphism, it's actually a little easier to prove a general theorem that "evaluation maps are homomorphisms":
If [tex]A \subset B[/tex] are rings and [tex]\xi \in B[/tex], then the "evaluation at [tex]\xi[/tex]" map [tex]\mathrm{ev}_\xi: A[X] \to B[/tex] given by extending the inclusion map [tex]A \hookrightarrow B[/tex] by sending [tex]X \mapsto \xi[/tex] is a homomorphism.
(You can generalize this a little further by letting [tex]A[/tex] be embedded in [tex]B[/tex] via a homomorphism [tex]\varphi: A \to B[/tex] rather than directly a subring of [tex]B[/tex]; then the evaluation map extends [tex]\varphi[/tex] by sending [tex]X \mapsto \xi[/tex], rather than extending the inclusion map.)
