Acceleration and the twin paradox
172 replies · 21K views
PAllen said:
What exactly is your point? Books on classical mechanics routinely cover non-inertial coordinate systems.
The considerations of non-inertial reference frames are not well studied. Or you pretend, that "There is nothing new to be discovered in physics now. All that remains is more and more precise measurement" (supposed to be said by Lord Kelvin)? As simplest example. Inside accelerating rocket holds ##d^2x/dt^2=a={\rm const}##. What is the theoretical derivation of this formula? Answer: 1) take Newton's second law in inertial frame, latter is co-moving with the rocket for a given moment ##d^2x'/dt^2=0##, 2) make coordinate transformation ##x' = x-a\,t^2/2##. Please give theoretical derivation of this coordinate transformation. The linear transformation was derived in Special Relativity from only two postulates. Which postulates would lead to the above non-linear transformation?
on Phys.org
There doesn't need to be any derivation of a coordinate transformation. You can use any coordinates you like. What is special about the Lorentz transformations is that they preserve the following properties:
  1. For an object with no external forces acting on it, [itex]\frac{d^2 x^i}{dt^2} = 0[/itex] (an object in freefall has zero coordinate acceleration)
  2. The path of a pulse of light obeys [itex]\frac{d^2 x^i}{dt^2} = 0[/itex] and [itex]\sum_i (\frac{dx^i}{dt})^2 = c^2[/itex]
  3. The proper time [itex]\tau[/itex] on a standard clock at rest ([itex]\frac{d x^i}{dt} = 0[/itex]) satisfies [itex]\frac{d\tau}{dt} = 1[/itex].
  4. Etc.
The inertial coordinate systems are ones for which the laws of physics take a particularly simple form, when written in terms of coordinates. But you can use whatever coordinate system you like to describe physics, provided that you are careful to work out what the laws of physics look like in this new coordinate system.
I claim exactly that: "non-inertial reference frames are well studied in classical mechanics for over 200 years, and in SR for over 90 years". Coordinates don't change physics, and the study of non-inertial frames is question of appropriate mathematics not physics. If you disagree, well that is not just 'your choice' as far as physicsforums goes, because that means you reject established mainstream physics, which is not permissible in pysicsforums.
dmitrrr said:
1) I am sorry, physicsForums administration. Am I talk too much? But I am not using f-words or else insults, so please be tolerant enough.
2) By having two definite coordinate systems: one inside the rocket and one outside, we have no freedom of choosing the coordinates. Therefore, there is unique coordinate transformation. I argue, if you have system A and system B, then you can derive the transformation f, so A = f(B).
It is nonsense claim coordinate systems are uniquely chose. If you ignore gravity, you can, at most, say there is family of coordinates in which laws of physics take their simplest form - standard inertial coordinates (if you include gravity, there is no such thing as a global inertial coordinates at all). However, nothing requires use of these to get the correct physical prediction from SR. Further, there is no concept of a preferred coordinates for an accelerating rocket. There are many choices for coordinates in which the rocket is the origin, with no reason to prefer one. Even more, there is no good reason for the rocket to use coordinates for which the rocket remains the origin.
PAllen said:
Many physicists have criticized this statement. In fact, it describes an invalid coordinate system (the same distant event has multiple coordinates, while a well formed coordinate chart is one-one with events).
Brian Greene didn't seem to regard his example (of simultaneity at a distance, under acceleration) as being "one choice among many". And he didn't seem to regard the fact, that the accelerating traveler's perspective that he described isn't invertible, to be a problem. Apparently, he doesn't believe that the accelerating traveler's perspective is required to be a chart. Brian's credentials seem impeccable to me. I certainly wouldn't be so quick to dismiss his example.
PAllen is correct. This is one reason that pop sci books are NOT considered acceptable references on PF, even when written by someone with impeccable credentials.
Here is a good reference explaining the mathematical requirements of a valid coordinate chart (chapter 2). As PAllen says one of the requirements is that it must be 1-to-1.
http://arxiv.org/abs/gr-qc/9712019
Thanks to everyone that has responded to this thread so far, it has been quite the learning experience. I feel I've gained some insight on the matter and wanted to check my understanding against the group here.As far as I see it, there are really two issues here, one is the math involved relating to Minkowski space versus ordinary “folk” conceptions of Euclidean space, and the other is a more visuo-spatial conceptual understanding of space, time, light, and moving matter. The good news is that I think I’ve come to terms with the former, but I’m still struggling with the latter.In post #7 of this thread, I put up a video of Susskind discussing the twin paradox at 1:29:00. It was only a couple minute discussion, but right after that he goes on to talk about how the “hypotenuse” of the space-time (ST) graph in the example of the twin paradox is actually shorter than the sum of the sides because of how the Minkowski 4-vector is set up, and this is where the sort of counter-intuitive nature of spacetime bites people. For instance, if we take the ST diagram ghwellsjr posted in another thread,
ghwellsjr said:
Here is a spacetime diagram to illustrate what I have been saying. The Earth twin is shown as the thick blue line with dots marking off increments of one year. The thick red line is the rocket twin. The thin lines show yearly signals propagating at the speed of light from each twin to the other one.
we see that the traveling twin A (we’ll call her Alice)’s “path” through this ST diagram visually looks longer than Bob’s. However, the sides of the symmetrical stacked right triangles are subtracting not adding, as in the Euclidean case, and thus the magnitude of Alice’s resultant vector, or proper time/invariant interval, is actually shorter than Bob’s, not vice-versa. That is, for Alice’s journey out to her turnaround point 3 light years away, her time/age is (tau)^2=(5)^2-(3)^2= (tau)=4 years, whereas Bob’s is (tau)^2=(5)^2-(0)^2=(tau)=5 years.
Now I do have a little confusion here in the above example. That is, who’s proper time are we measuring or using here, Bob’s or Alice’s or both? (tau)=proper time is supposed to be invariant, right? But in the above example (tau) is 5 for Bob and 4 for Alice. Should I have re-arranged one of those equations?As m4r35n357 mentioned, everything is contained within the ST interval, particularly the Lorentz transformations, because if you plug in Alice’s speed into the time dilation equation (3/5c, or 0.6c), then you come up with the exact same answer as in the 4-vector example above. So, if you can wrap your head around the 4-vector and how space and time subtract from one another, the twin paradox makes sense to me from this perspective, mathematically at least.
We are just comparing the total elapsed proper time for Bob and Alice from when they are separated to when they meet again. Each person has his own elapsed proper time which depends on his spacetime trajectory. The elapsed proper time is what we are colloquially calling their "age".
Simultaneity is relative, so there isn't really an "absolute" proper time elapsed for Bob at Alice's turnaround point.
The turnaround point is absolute for Alice, since there is an acceleration there, which is an absolute event. The moment of separation and the moment of reunion are also absolute events, since they are defined by the intersection of worldlines. The total elapsed proper time for Alice from the moment of separation to the moment of reunion is 2 X 4 years = 8 years, but the total elapsed proper time for Bob is 10 years.
While mathematically the twin paradox appears to make sense to me, trying to understand the twin paradox from a more intuitive visuo-spatio-temporal perspective is more tricky. I will gratefully borrow another one of ghwellsjr fine ST diagrams in order to set up an example scenario:
ghwellsjr said:
Here is another spacetime diagram to illustrate this scenario:
In the scenario I want to set up around this ST diagram, we have Alice and Bob each residing on their own planets in a common rest frame 3 light years apart. For simplicities sake, let’s say that Alice and Bob “see” each other through a constant mutual radio signal of 100 hz emitted from each planet directed at the other. We can say the information sent is amplitude modulated. So now perhaps we can define the spacetime between Bob and Alice as these mutually transmitted signals at 100 hz 3 light years apart. Using the above ST diagram, then, we can almost look at the ST between Alice and Bob as sort of a “box” of ST enclosing their mutual rest frame. If Alice and Bob stay on their planets, then each will see and continue to see the other as they were 3 years in the past.
Now, say, all of a sudden Alice gets lonely for Bob, jumps on a spaceship, and starts heading for Bob’s planet. What happens here? Well, we can see clearly that a symmetry in this situation indeed has been broken. That is, Alice will immediately begin to see signals sent from Bob that weren’t supposed to reach her until much later. So, in effect, she will begin to see Bob aging at an accelerated rate. Furthermore, the signal she receives from Bob will be blue shifted from 100 hz to 100+ hz. Bob, on the other hand, experiences none of these differences. So, seeing this was interesting to me because it demonstrates how an asymmetry can exist between Alice and Bob that can identify which one has broken the symmetry. Again, as m4r35n357 mentioned in post #37, it doesn’t look as if acceleration per se makes much difference here, other than the initial breaking of the mutual rest frame, if she travels to Bob’s planet at 0.6c, she will arrive there in 4 years, while in the same interval, Bob will have aged 5 years. It’s all in the velocity and the spacetime interval/LT.
What I am having trouble seeing from this scenario, however, is how this happens from the perspective of the mutually sent radio signals. That is, it seems as though, granted, Alice will see Bob getting older at an accelerated rate while Bob will not see the reciprocal for a full 3 years, but it seems that, as Alice approaches Bob’s planet, the signals she has been sending will simply “stack up” on Bob during her final approach. Thus, as Alice is coming in the final stretch, Bob will see the entirety of Alice’s aging over her trip at an extremely accelerated rate. I guess I don’t see how, at the end of Alice’s trip, the balance of the sent radio signals (say there was one “marker” signal sent each year as in ghwellsjr example) don’t add up at the end. Again, in ghwellsjr example, at the point at coordinate time 0 whereby Alice begins her trip toward Bob, I see that Alice crosses 8 blue lines before she arrives on Bob’s planet, while in the same time frame, Bob only crosses 7 red lines coming from Alice. Am I reading that correctly and is that significant quantitatively? And if so, how?
In any case, again, I’m just trying to piece this all together as best I can and see where I may be on the right track and where I’m off. Thanks again for everyone’s comments.
It would be exactly 200 Hz. You can see this in the diagram as the red dots mark off 1-year increments for Alice and the thin blue mark off the Bob's 1-year increments as seen by Alice. There are twice as many thin blue lines as red dots during the time that Alice is traveling.
Radio signals, like light signals, don't have a perspective, so I'm not sure what you mean by this.
Both these accelerated rates are exactly double, that is, Alice sees Bob's clock going twice the rate of hers and Bob sees Alice's clock going twice the rate of his.
Yes, you are reading that correctly and it is significant quantitatively. It shows how when Alice traverses the distance between the two planets, she "loses" one year because of her speed. If she had gone slower, she would lose less time and if she had gone faster she would lose more time. But the thin lines show how Bob observes her gaining time so that he sees her originally as being 3 hours behind him to being only 1 hour behind him. Alice, on the other hand, sees Bob originally as being 3 hours behind her to being 1 hour ahead of her.
It appears that you are pretty much on the right track and maybe just don't realize it.
Alice's dots are spaced further apart, too. But you have the right idea about pythagoras and subtracting, that is the essence of the relationship between time and space (the spacetime interval, to labour the point), notice we have a "3-5-4" triangle, not by accident! . Everyone has their own proper time, and you have worked out both Alice's and Bob's in this instance. I think you have it, just don't panic ;)
Alice sees Bob's signals blueshifted for her entire journey--that is, she sees Bob's clock running faster than hers for the entire 4 years of her trip. So Bob's clock starts out 3 years behind hers (that is, the signal she receives from Bob when she starts her journey shows his clock 3 years behind her clock's reading when she starts); Bob's clock gains 4 years on Alice's during the journey (she sees 8 years' worth of Bob's signals in 4 years of her own time); so Bob's clock ends up reading 1 year ahead of Alice's when she reaches him.
Bob, however, only sees Alice's signals blueshifted for 2 years (5 years total time elapsed on Bob's clock, minus the 3 years of light travel time that it takes before Bob receives the signal Alice emits when she starts her journey). So even though he sees all of Alice's signals during the journey "stacked up" during that 2 years, it still isn't enough for her clock to "catch up" to his. He sees her clock reading 3 years behind his when Alice's "start of journey" signal reaches him; Alice's clock gains 2 years on his during the journey (he sees 4 years' worth of Alice's signals in 2 years of his own time); so when Alice reaches him, her clock is 1 year behind his.
I'm not saying that Brian Greene apparently thinks that charts aren't required to be invertible.
I'm saying that Brian Greene apparently thinks that the accelerating traveler's perspective isn't required to be a chart.
Simultaneity requires a chart. Simultaneity means that two events share the same time coordinate. A time coordinate is part of a chart. So simultaneity necessarily implies a chart.
A "perspective" is not well-defined. But insofar as a "perspective" says anything about simultaneity then it must involve a chart.
what people want most from a "coordinate system of the traveling twin" is to be able to say: When the traveling twin is X years old, how old is the stay-at-home twin?
PeterDonis said:
And the correct answer to this question is "mu"; as Nugatory pointed out, the question is ill-formed. IMO it's better to just face that up front, rather than trying to salvage people's pre-relativistic intuitions in some form. Understanding why the question is ill-formed is a key part of understanding relativity.
I think this is in fact what confused folks (like myself) what to know in order to remove the paradox. On the outbound leg, in the travelers frame, the stay at home clock runs slower, after the turnaround point in the travelers new frame, the stay at home clock still runs slower. These are both true statements from the Lorentz transform. Just as true as the calculation made above by the stay at home twin using the Lorentz transforms to predict that the returning twin will be younger.
So the paradox is how can we explain the fact that the travelers clock is behind the stay at home clock at the end of the trip from the travelers viewpoint, while on both legs of the journey, to the traveler, the stay at home clock ran slower. We can say what happens in the traveling twin's frame (which is not inertial at the turning point, but is on both legs). I believe the following is an answer.
At the turn around point, an abrupt change in the traveler's time coordinates occurs because the inertial frame of the traveler changes. When the traveler changes inertial frames in turning back, what was the current time on the stay at home clock in the outgoing frame changes abruptly to a later time in the new frame. The size of this jump depends on how far the traveler is from the stay at home twin and the travel velocity. This jump in the stay at home clock more than compensates for the slower running of the stay at home clock on the outbound and inbound legs of the journey as observed in the traveler's frame.
This is just a closer look at how the simultaneity relationship for the traveler changes. The change in time frames accounts for the apparently "missing" aging of the stay at home twin according to the traveling twin.
So if you want to ask in the travelers frame, how old is the stay at home twin, the answer is that the stay at home twin ages slower on the outgoing leg. At the turn around point, the stay at home twin suddenly ages by a large amount, on the return trip, the stay at home twin ages more slowly than the traveler.
If you make the turn around less abrupt, then for the traveler the stay at home twin will age very quickly during turn around but not so abruptly.
The situation is asymmetrical because the stay at home twin remains in the same inertial frame during the whole trip, while the travelers frame changes.
I don't know if that helps anyone else, but it helps me account for the "missing" aging of the stay at home twin. What this scenario looks like to the traveler when watching the stay at home clock with a telescope is different because the time delay of the observation is changing with distance.
What makes you believe that from the traveler's viewpoint the stay at home clock runs slower at all?
Excellent post! I think you've nailed it.
CKH said:
The situation is asymmetrical because the stay at home twin remains at rest in in the same inertial frame during the whole trip, while the travelers frame changes.
I added the bolded text to make it clear what being "in" an inertial frame, in the sense you are using the term, actually means, physically. I think this is an important distinction because the worldlines of both twins can be described in any inertial frame you like; when the traveling twin turns around, his worldline does not "disappear" from one inertial frame and "appear" in another. It is present in all inertial frames all the time. All that changes is the behavior of the traveling twin's spatial coordinates in different frames (before he turns around his spatial coordinates are constant in the outgoing frame; after he turns around his spatial coordinates are constant in the incoming frame).
To be specific, I mean within the two legs of the trip, where the traveler is at rest in an inertial frame (a different frame in each leg), the Lorentz transform tells us that the home clock runs slower because the home clock is moving wrt to the traveler's rest frame.
To clarify more. At the turnaround (assume it is smooth and gradual turn), the traveler's rest frame is changing. As a result the "now" for the traveler is changing (his time axis is tilting) wrt to the stay at home clock. So the stay at home clock runs fast in the traveler's rest frame during turn around. When the turn around is completed and the traveler's rest frame is once again an inertial frame, the home clock once again runs slower than the traveler's.
Yes, that is the correct way to say it. The traveler is at rest in an inertial frame. In the scientific literature that frame is known as the momentarily co-moving inertial frame, or MCIF.
And this is incorrect because the traveler's rest frame is not an inertial frame. Therefore the Lorentz transform does not tell us anything about it at all. The correct way to say this would be to use the same language as you used above. "The Lorentz transform tells us that the home clock runs slower because the home clock is moving wrt to the inertial frame where the traveler is at rest."
Note the difference. "The inertial frame where the traveler is at rest" vs. "the traveler's rest frame". The Lorentz transform tells us about the former and the standard time dilation formula applies to the former because it is inertial. The Lorentz transform tells us nothing about the latter and the standard time dilation formula does not apply to the latter because it is non-inertial.
More correctly, the traveler's MCIF is changing. The traveler's rest frame is not changing, it is simply non-inertial.
One of the big standard pitfalls that students fall into regarding the twins scenario is the following. They chop off pieces of several different reference frames and stitch them together haphazardly. Then, like Dr. Frankenstein, they are surprised when their creation fails to behave normally.
Pieces of a pair of frames stitched haphazardly together does not form a valid chart, and if you do the stitching carefully it still does not form an inertial frame. It should be obvious that a Frankenstein frame will not behave like an inertial frame.
I just thought of another way of looking at the problem that actually makes more sense to me than looking at it from a strictly time dilation perspective.Let’s take again my scenario and ghwellsjr spacetime (ST) diagram from my post #99. Now, another way to look at the asymmetry presented when Alice begins to accelerate toward Bob’s planet is that the space between her and Bob becomes asymmetrical, and that asymmetry is triggered by Alice breaking the symmetry of their mutual inertial frame. Hence, now all of a sudden, according to Alice, her and Bob’s planet are not separated by 3 light years, they are separated by 2.4 light years. That’s how she now sees it, the instant she leaves her planet and starts moving toward Bob’s (assuming instant acceleration to 0.6c). Again, Bob doesn’t experience this, Bob still sees the distance between his and Alice’s planet to be 3 light years, and in fact, will remain seeing 3 light years as the distance even after Alice has landed on his planet.
So basically what we have here is a situation whereby both Bob and Alice experience their own proper time passage “normally” relative to one another, and, in addition, both agree on Alice’s velocity of 0.6c. What they disagree on primarily is the distance between their 2 planets. According to Alice, she is traveling at 0.6c for 4 years and, thus, is traversing a distance of 2.4 light years. According to Bob, however, Alice is traveling at 0.6c and is traversing a distance of 3 light years, but this is taking her 5 years to do, not 4. The only way to reconcile this discrepancy, for Bob, is for him to see her clock running at 4/5ths the speed of his, and for Alice to see Bob’s running at 5/4ths the speed of her clock. Am I accurate in my above assessment? One question I have here, though, is who looks length contracted to whom during the journey? It would seem that, since Bob’s conception of space hasn’t changed, he should see Alice’s spaceship in the normal dimensions, only see her clock running slower. Alice, on the other hand should see Bob’s world as contracted since her conception of the space has contracted from 3 light years to 2.4 light years. This model, however, seems to disagree with the popular conception that Bob sees both Alice’s clock slow and spaceship contract. Which one is it?
Also, it’s intuitive to see how, once Alice lands on Bob’s planet, her conception of the space between hers and Bob’s planet will once again revert to 3 light years, as will her perspective on Bob’s length, he will no longer be contracted. What might be less intuitive, though, is the fact that, although the conception of space will revert to “normal” once Alice and Bob are once again in a common rest frame, Alice will retain her younger age forever, presumably. In other words, their length/sizes will renormalize to the point where Alice’s trip doesn’t leave a lasting trace on their relative size differences, but the relative differences in their ages will leave a lasting trace. Why is such an asymmetry permanent in the time domain but only transient in the space domain?
As far as what Alice and Bob actually see, each one sees the other's clock running fast (not slow), because of Doppler blueshift (as has already been discussed in this thread). Bob calculates that Alice's clock is running slow compared to his during her journey, by taking the raw data he actually sees (the Doppler blueshifted signals he gets from Alice), and correcting it for light travel time and the distance Alice was from him (according to the inertial frame in which he is at rest) when she emitted each signal. Alice does a similar calculation for Bob's clock, using the inertial frame in which she is at rest. So time dilation is not something that is directly observed; it's calculated based on other observations.
Length contraction is similar to time dilation in this respect: it's not directly observed, it's calculated based on other observations. For example, if Alice emitted two light signals at each tick of her clock, one from the front of her ship and one from the rear, Bob could use the differing times at which he received the front and rear signals, along with their "time stamps" (what Alice's clock read when each one was emitted), and along with the other data he has, to calculate that Alice's ship is length contracted. But he won't directly observe it as contracted. If it's coming straight at him, he'll just directly observe the nose of the ship, which won't tell him anything about its length; if its direction of motion has a component perpendicular to his line of sight, he will directly observe the ship to be rotated (Google Penrose-Terrell rotation), not contracted. (And again, similar remarks apply to Alice observing Bob.)
Ah yes, an important distinction. Thank you for reminding me of that.
I don't disagree, but note that I was assuming the simplified version of the trip that was being discussed. The traveler immediately reaches his "cruising speed" on the outbound leg, he then turns (reverses) quickly and then cruises back on the inbound leg. This means he is at rest in a constant inertial frame which is moving wrt to the home twin during the cruising legs of the journey. The outbound cruising frame is different from the inbound one. The Lorentz transformation shows that the home clock ticks slower in both these legs of the traveler's journey.
Where things change (in this simplified scenario) is in the turn around. During the turn around, the traveler's rest frame is not inertial. However, at every instant of the turn around there is a comoving inertial frame in which the traveler is instantaneously at rest. So during this period of turn around the traveler's instantaneous inertial rest frame is continuously changing to a different inertial frame.
During that turn what is now for the traveler changes wrt the home clock. It changes because simultaneity with the home twin's world line is different in each momentary inertial rest frame of the traveler during his turn. [/QUOTE]
Yes the traveler's rest frame (over time) is not inertial, but at each instant it coincides with an inertial frame.
This is a cool thing in SR that allows you to analyze arbitrary motion with the Lorentz transforms. At every moment, an object is at rest in some inertial frame. The clock hypothesis tells us that acceleration (per se) does not affect clock rates. The only thing that affects clock rates is the current relative velocity of the two clocks. Those rates can always be computed with the Lorentz transform.
When an object accelerates, the particular inertial frame in which the object is at rest is continuously changing. Each of these inertial frames defines a line of simultaneity in spacetime, at the instant when the object is at rest in that frame. In the case of the traveler, the point at which this line intersects the home clock's time axis, gives the home clock time at that instant in the traveler's rest frame.
I hope I've got that right. You have to be very careful in describing frames or you mess up the story.
In principle, length contraction could be observed directly (but not from a single position). Imagine a photographic plate longer than the object you want to measure. As an object traverses the plate (parallel to and very near to the plate) a continuous string of flash bulbs are flashed simultaneously to illuminate the object and create an an "accurate" instantaneous image of the moving object on the plate.
You cannot capture this with a camera at some point along the path. The light travel time from each part of the object to the camera is different which distorts the picture.
This is another confusing factor when talking about these SR senarios. There is a notion of simultaneity in an inertial frame, however an observer at rest at some particular position in the frame does not see simultaneous events as such because (in general) the light from each event does not reach him simultaneously.
The length change disappears when Alice reaches Bob and stops. The clock rate change also disappears when Alice reaches Bob and stops. The distinction is that during the trip the difference in clock rates accumulates to a difference time which does not disappear.
CKH said:
[..] The only thing that affects clock rates is the current relative velocity of the two clocks. Those rates can always be computed with the Lorentz transform.[..]
Almost: "the current relative velocity of the two clocks" has issues, grammatically I think that it can only mean the velocity of one clock relative to the other clock. By leaving out referral to inertial reference systems, you reintroduce the twin paradox! ;)
Correcting your phrasing is a bit tricky if you want to maintain "affects" in your sentence; but it's similar to "kinetic energy" in classical mechanics, so you can get inspiration from there. :)
That's just what I just said. My question is why is there such a distinction?
CKH used a keyword that you did not use (nor something similar to it): "accumulates". And he tried to clarify that there is not inherently a distinction between the "time domain" and the "space domain": clock frequency and its inverse, clock period ("time domain") as well as length ("space domain") do not accumulate. In contrast, clock time is commonly the summation of registered clock periods; as a result, clock time has memory - and it works just the same for age.
