Acceleration in an accelerated reference frame? Yes/no/maybe?
The discussion revolves around a physics problem involving an object dropped in an accelerating lift. The original poster questions how the downward acceleration of the lift affects the time it takes for the object to hit the floor, considering gravitational acceleration.
  • The original poster attempts to understand the relationship between the lift's acceleration and the time taken for the wallet to fall. Some participants question the assumptions about the initial conditions and the effects of acceleration on perceived weight.
Participants are exploring the implications of the lift's acceleration on the problem. Some guidance has been offered regarding the relationship between apparent weight and acceleration, but there is no explicit consensus on the approach to solving the problem.
The original poster indicates uncertainty about the problem's setup and acknowledges that it may not strictly be homework, although it is related to their studies in physics.
bigdog989
Hi, my question is this, say you’re in a lift that is accelerating downwards at 5ms and you were to drop a 200g wallet from say 1.3m off the floor of the lift, assuming gravity is 9.8ms, how long would it take the wallet to hit the floor of the lift?
Does the downwards acceleration of the life affect the time taken, I am so unsure?
This looks like homework, bigdog989. Our policy on homework is pretty simple: We help you do your homework. We do not do it for you. You need to show some work on this topic before we can help you.
Oh fair enough, it's not really homework though, it's a question I found while reading up on referrence frams, but it gave no answer, as a student studying phyics it seemed quite interesting and I just want to find out how it all works, problem is I'm not entirely sure where to start, if they both started at rest this would be simeple but they don't
I'm sorry again I probably should have posted this in the homework section anyway
Think about it. If the lift accelerates downwards really quickly, do you feel lighter or heavier? The apparent force divided by mass is equal to acceleration. In this case, acceleration would be g-a: gravity provides g, but the elevator is accelerating at a, so the relative acceleration is g-a.
Oh ok, so I guess I’ve been over complicating this whole problem, you feel lighter as a lift accelerates downwards, thus you feel less acceleration..
So for this situation g-a = 9.8-5 = 4.8
Then I’d use
x=ut+1/2at^2
1.3=1/2 * 2.8 *t^2
1.3=1.4t^2
1.3/1.4=t^2
sqrt(1.3/1.4)=t
Would this be the way to work it out?
  • · Replies 144 ·
10K
17K
