Acceleration of a particle moving around a circular path.
The discussion revolves around a physics problem involving a particle moving along a circular path with constant linear acceleration. Participants explore how to determine the total acceleration after a specified time, considering both centripetal and tangential components of acceleration. The conversation includes elements of homework assistance and conceptual clarification.
  • Homework-related
  • Some participants suggest using cylindrical coordinates to express acceleration, while others argue this may complicate an introductory physics problem.
  • There is a discussion about the necessity of knowing the initial speed of the particle to solve the problem, with some participants questioning whether this information was omitted.
  • One participant notes that the problem likely involves both centripetal and tangential components of acceleration, which should be considered in the solution.
  • Some participants express uncertainty about the appropriate equations to use, indicating a lack of access to textbooks or online resources.
  • There is a mention of the particle starting from rest, which is inferred from the problem statement.
Participants do not reach a consensus on the best approach to solve the problem. There are competing views on the use of cylindrical coordinates and the necessity of initial speed information, indicating unresolved aspects of the discussion.
Some participants highlight the potential confusion between centripetal and tangential acceleration, emphasizing the need to clarify these concepts in the context of the problem. Additionally, the discussion reflects varying levels of familiarity with the topic among participants.
This discussion may be useful for students studying classical mechanics, particularly those grappling with concepts of acceleration in circular motion and seeking clarification on problem-solving approaches in introductory physics contexts.
necromanzer52
A particle moves along a circular path of radius 6 m, with constant linear acceleration of 1 m/s/s. Determine its total acceleration after 2 seconds.
Can't find any. That's why I'm here.
I assume there's some equation I can just plug numbers into to calculate the acceleration due to the fact it's moving in a circle, then use pythagoras to get the magnitude, but I can't find any. Either that or it's a trick question and the answer is always 1 m/s/s.
No trick question.
The safe thing is to dig up your expression for acceleration in cylindrical coordinates. However, it can also be done by realizing there are two accelerations involved and they add vectorially. Assume the motion is in the direction of increasing ψ.
Oh. It's that big long one with the four components, isn't it? And I integrate to get expressions for velocity & position.
What is ψ?
What is ψ?
Yes, the total expression for the acceleration vector in 3 dimensions has (of course) 3 components, of 2 terms each.
ψ is the angle part of the cylindrical coordinte system. The PF 'quick symbol' table doesn't have a phi, unfortunately. Maybe should have used θ instead.
Why do you want to integrate to get v and s? The problem doesn't ask for them ...
This appears to be either a high school physics or a college freshman physics problem. If so, then by "total acceleration" I presume they mean centripetal and tangential components of acceleration. Check your physics textbook for the discussion of centripetal or circular motion (not to be confused with rotational motion, that is different). The relevant equation for centripetal acceleration should be there.
Also, why is this (apparently) introductory physics problem being posted in the engineering homework area? Can you clarify what course subject this assignment is for?
Final note: this problem cannot be solved without knowing the initial speed of the particle. Did you by any chance omit some information? Does the phrase "starts from rest" happen to appear in the problem statement somewhere?
rude man said:
No trick question.
If this is an introductory physics problem as I strongly suspect, then bringing in cylindrical coordinates is an unnecessary complication.
It's a lot more complicated if you don't!
I posted it here as I'm a college freshman in engineering. And as this is a classical mechanics question it seems like the right board.
Anyway, I don't have a textbook and I can't find the relevant equation on the internet.
Also it says it starts to move, so I take that to mean it started from rest.
I defer to Mr. Redbelly on this.
Your situation sounds rather unusual: an engineering student who has not taken introductory physics yet.
Be that as it may, below are a couple of online references for acceleration of particles that move in a circle. But first, some important things to keep in mind are:
1. The velocity (a vector) always points in the direction tangent to the circle, no matter where the particle is on the circle. We call this the tangential direction.
2. The acceleration (also a vector) can have one or two components. It always has a component toward the center of the circular path (the centripetal acceleration), which causes the particle to curve to the left or right. And it may or may not have a tangential component (in the direction of the velocity) -- it does if the particle is speeding up or slowing down, as in your problem. If the speed were constant, then the tangential acceleration would be zero.
You can find out more of the basics here:
http://en.wikipedia.org/wiki/Acceleration#Tangential_and_centripetal_acceleration
http://theory.uwinnipeg.ca/physics/circ/node6.html
Hope that helps. Once you understand better what's going on, solving this problem pretty much begins with figuring out the speed of the particle (that starts from rest :smile:) after 2 seconds.
  • · Replies 37 ·
  • · Replies 29 ·
  • · Replies 39 ·
  • · Replies 16 ·
