Acceleration of a particle on a parabola
A particle moves along the parabola defined by the equation y² = 2px at a constant speed of 1000 m/s. The acceleration of the particle can be determined using the parametric equations r(t) = (b²t²/(2p), bt). The magnitude of the acceleration is given by |a| = b²/p, indicating that it is dependent on the parameter p. The discussion highlights the complexity of deriving the acceleration due to the need for a differential equation, suggesting that numerical methods may be required for solutions.
  • Understanding of parametric equations in physics
  • Knowledge of calculus, specifically differentiation
  • Familiarity with the concepts of tangential and centripetal acceleration
  • Basic understanding of differential equations
  • Study the derivation of acceleration in parametric motion
  • Learn about the radius of curvature in curvilinear motion
  • Explore numerical methods for solving differential equations
  • Investigate the relationship between speed and acceleration in non-linear paths
Students in physics or engineering courses, particularly those studying mechanics and differential equations, as well as anyone interested in the dynamics of motion along curved paths.
Jenny Physics
A particle moves along a parabola on the x-y plane with equation ##y^{2}=2px## with constant speed ##1000m/s##.What is the magnitude of its acceleration?
Parametric equations ##\vec{r}=(b^{2}t^{2}/(2p),bt)##.
##\vec{v}=\frac{d\vec{r}}{dt}=(b^{2}t/p,b)\implies |\vec{v}|=b\sqrt{b^{2}t^{2}/p^{2}+1}=1000##
##\vec{a}=\frac{d\vec{v}}{dt}=(b^{2}/p,0)\implies |\vec{a}|=b^{2}/p##
Not sure were to go from here.
I think this is more complicated than it needs to be, with the added parameter.
You could use ## \vec{r}=(\frac{t^2}{2p}, t)##. This gives the proper relationship between the x and y components. It also makes for a simpler expression for ##\vec v## and the magnitude of the acceleration depends only on p.
BTW, very nice job in formatting your work!
Likes Jenny Physics
It looks to me like the ##b## must depend on ##t## for the constant speed to happen. And consequently the acceleration must depend on ##t##.
Likes Jenny Physics
After thinking a bit more about it, I see no reason to assume a form for ##y##. So I would start by assuming a parameterization like $$\vec r(t) =\left \langle \frac{y^2(t)}{2p},y(t) \right \rangle$$Then see what ##|\vec r'(t)| = C## gets you. I don't think it will be as simple as ##y=bt##.
Likes Delta2 and Jenny Physics
##|\vec{r}'|=\frac{dy}{dt}\sqrt{\left(\frac{y^{2}}{p^{2}}+1\right)}=C##.
Likes Delta2
Well, I haven't worked it all out, but my thought is that you want to keep the variable ##t## if you are going to use the parametric form.
Likes Jenny Physics
I fixed an issue in post #5. It seems I end up with a differential equation.
Yes, I think it gives a DE and it is about to get very messy. It is making me curious what level course you are taking where this problem came from. Have you had DE's? This problem is looking to me like it is non-trivial unless there is some clever insight that I am missing. The DE I came up with will only give ##y(t)## implicitly and the second derivative looks like it isn't going to be simple to work with.
Likes Jenny Physics
Yes I have taken a DE class (this is from a physics class that assumes knowledge of DE). The equation you end up would have to be solved numerically?
The acceleration along an in-plane curve has a tangential and a centripetal component.
https://www.real-world-physics-problems.com/curvilinear-motion.html
As the speed is constant, the tangential acceleration is zero. The centripetal acceleration is equal to V2/R where R is the radius of curvature and V is given. It will depend on the position along the curve.
Likes Jenny Physics and Delta2
