Acceleration of blocks on a slope
Two blocks connected by a string over a pulley are analyzed for acceleration, with block A on a 30-degree incline and block B hanging. The frictional force for block A is calculated, leading to equations of motion for both blocks. The initial assumption that block B is pulled up due to block A's weight is questioned, highlighting the importance of slope direction and friction. After several calculations, discrepancies arise in the acceleration results, prompting further examination of the equations used. The discussion emphasizes the need to correctly account for the forces acting on both blocks to determine the accurate acceleration.
Northbysouth
Two blocks are connected by a string that goes over an ideal pulley. Block A has a mass of 3.00 kg and can slide over a rough plane inclined at 30 degress to the horizontal. The coefficient of kinetic friction between block A and the plane is 0.400. block B has a mass of 2.77 kg. What is the acceleration of the blocks?
fk = ukFn
Fn - 3gcos(30)
Fn = 25.4611
fk = 0.4*25.4611
= 10.1845
Using force diagrams I identified the forces acting on the blocks to be:
T is the tension in the rope
For block A
T - fk - 3gcos(30) = 3a
For block B
T - 2.77g = 2.77a
Then I combine them
fk - 3gsin(30) -3a = 2.77g - 2.77a
a = 98.4
I know the answer is 0.392m/s^2 but I don't know where I'm going wrong. I assumed that block B is being pulled up because block A has a greater weight. Is this a wrong assumption?
Hi Northbysouth! :smile:
a = 98.4
but you still need to find fk :confused:
depends on the slope …
obviously, if the slope was 0°, then B would win! :wink:
I found fk = 10.1845
Could you be more specific about the slope? How do I determine whether the friction is acting in the same direction as the tension or in the opposite direction?
to find the direction of friction, imagine that there's no friction, and see which way the blocks go :smile:
(and I'm off to bed :zzz:)
I ran the calculations again with friction acting opposite to the tension.
T - 10.1845 - 3gsin(30) =3a for block A
T =2.77a + 27.146 for block B
I substituted T into block A's equation:
2.77a+27.146 -10.1845 - 3gsin(30) = 3a
a = 0.520145
This still seems a ways off from 0.392. Am I missing something?
(just got up :zzz:)
a = 0.520145
i] if you subtract equation B from A (so that the RHS is 3a), those first two terms on the LHS should be minus
ii] but your B equation is wrong if you're measuring a downwards (ie, if B is going down) …
then a = mg - T, not T - mg :wink:
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 20 ·
