Acceleration of blocks on a slope
5 replies · 10K views
Northbysouth
Two blocks are connected by a string that goes over an ideal pulley. Block A has a mass of 3.00 kg and can slide over a rough plane inclined at 30 degress to the horizontal. The coefficient of kinetic friction between block A and the plane is 0.400. block B has a mass of 2.77 kg. What is the acceleration of the blocks?
fk = ukFn
Fn - 3gcos(30)
Fn = 25.4611
fk = 0.4*25.4611
= 10.1845
Using force diagrams I identified the forces acting on the blocks to be:
T is the tension in the rope
For block A
T - fk - 3gcos(30) = 3a
For block B
T - 2.77g = 2.77a
Then I combine them
fk - 3gsin(30) -3a = 2.77g - 2.77a
a = 98.4
I know the answer is 0.392m/s^2 but I don't know where I'm going wrong. I assumed that block B is being pulled up because block A has a greater weight. Is this a wrong assumption?
Hi Northbysouth! :smile:
a = 98.4
but you still need to find fk :confused:
depends on the slope …
obviously, if the slope was 0°, then B would win! :wink:
I found fk = 10.1845
Could you be more specific about the slope? How do I determine whether the friction is acting in the same direction as the tension or in the opposite direction?
I ran the calculations again with friction acting opposite to the tension.
T - 10.1845 - 3gsin(30) =3a for block A
T =2.77a + 27.146 for block B
I substituted T into block A's equation:
2.77a+27.146 -10.1845 - 3gsin(30) = 3a
a = 0.520145
This still seems a ways off from 0.392. Am I missing something?
(just got up :zzz:)
a = 0.520145
i] if you subtract equation B from A (so that the RHS is 3a), those first two terms on the LHS should be minus
ii] but your B equation is wrong if you're measuring a downwards (ie, if B is going down) …
then a = mg - T, not T - mg :wink:
