Acceleration of object and displacement after given time
6 replies · 5K views
princesspriya
a kitten pushes a ball of yarn rolling toward it at 1.00 cm/s with its nose, displacing the ball of yarn 17.5 cm in the opposite direction in 2.00 s. What is the acceleration of the ball of yarn?
i used x=1/2(Vi+Vf)t to find the final velocity and i got 16.5.
than i used the vf=vi+at and got 7.75m/s^2 for the acceleration but my teacher told me its wrong so i have no clue like what i did wrong?
I would just use x = (vi)t + 1/2 (a)(t^2)
and remember that vi is -1.
y would vi be negative? it just says opposite its not saying east or west so you really cannot tell
You just need to know that the ball is moving in one direction to start with, and then ends up moving in a different direction. So you assign the direction it ends up going as being positive and the direction it was going at the start as being negative.
You get to choose. Lamoid is recommending a coordinate system in which velocities and displacements in the direction towards the cat are negative and velocities and directions away from it are positive, by definition. It doesn't matter if you choose things to be the other way around. But you have to pick a coordinate system and stick with it consistently throughout the problem, because velocities and displacements have both magnitude and direction, so you need some way to distinguish between motion in one direction and motion in the opposite direction.
so then if i picked to the east than everything would be positive correct? and i think my answer is correct since Vi=1 T=2 and X=17.5 but i mean he marked it wrong so i really am lost now
princesspriya said:
so then if i picked to the east than everything would be positive correct? and i think my answer is correct but i mean he marked it wrong so i really am lost now
Huh? No. This is a one-dimensional problem. Hence, the ball can either be moving THIS way, or THAT way (there are two possible directions along the axis). Clearly at the beginning of the problem the ball is moving in ONE direction (which you have the choice of calling negative or positive), and by the end of the problem, the ball has changed direction and is moving in OTHER direction (for which you must use the opposite sign from whatever sign you used for the initial direction, in order to distinguish the two). You need two signs.
