Acceleration when an object hits the ground
  • Context: High School
  • Thread starter Thread starter Uranium235
    Acceleration Ground
The discussion centers on the acceleration experienced by an object upon impact with the ground. It clarifies that while an object appears to stop upon landing, it actually undergoes rapid deceleration due to deformation of both the object and the ground. The concept of negative infinity acceleration is dismissed, as real-world physics involves elastic deformation and forces that prevent instantaneous velocity changes. Shock testing for rigid objects, such as bricks, can involve accelerations up to 30,000 m/s², highlighting the significant forces at play during impact.
  • Understanding of basic kinematics principles
  • Familiarity with concepts of acceleration and velocity
  • Knowledge of material properties, particularly elasticity
  • Awareness of shock testing methodologies
  • Research the principles of elastic deformation in materials
  • Study the physics of impact forces and their effects on objects
  • Learn about shock testing standards and procedures
  • Explore advanced kinematics, including non-instantaneous velocity changes
Students of physics, engineers involved in material science, and professionals conducting impact testing will benefit from this discussion.
Uranium235
Ok so this is a problem that's been bothering me ever since the first few days of learning kinematics.
We've been taught that when an object falls, the object has a positive velocity up until the moment that it hits the ground. At that moment, the velocity becomes zero. Wouldn't this imply that the acceleration that the object experiences when hitting the ground is negative infinity since it stops the very moment that it lands?
The falling object will dent the ground slightly. also the object itself will be deformed a little by the force of the impact. Thus the object does not stop the very moment it lands, it just slows down very rapidly.
Does it really stop the moment that it lands? Might not both the object and the ground bend a slight amount the moment it touches the ground?
That's not realistically what happens when an object hits the ground. Even if the the ground and the object were rigid, electrostatic forces that prevent solid objects from passing through each other would not result in an such an instantaneous change of velocity. In reality, though, an object and the ground probably would not be perfectly rigid, and the ground would deform downward, a bit like the object was being caught in a net.
Ok got it! Thanks for the answers guys!
No real objects are perfectly rigid, so even if there is no permanent change in shape of either the object or the ground, both will be compressed a bit during the time of the impact and then spring back again.
The accelerations when a "rigid" object like a brick falls on the ground can be very large - "shock testing" to check that accidental bumps and falls won't cause damage to objecst is often done at accelerations up to 3000 times the acceleration due to gravity (i.e. about 30,000 m/s2)
  • · Replies 26 ·
9K
