Solving Motorcycle Acceleration and Time Problems with Initial Velocity of 8m/s
  • Thread starter Thread starter highcontrast
    Accleration
The discussion focuses on solving a motorcycle acceleration problem with an initial velocity of 8 m/s, reaching a final velocity of 17 m/s over a distance of 30 m. The correct approach involves using the kinematic equation (Vf)^2 - (Vi)^2 = 2ax to find acceleration, as time is not provided. The initial attempt to use the equation d = acceleration + 1/2 a t^2 was incorrect due to the lack of a time value. The solution confirms that the acceleration is small and emphasizes the importance of selecting appropriate equations based on given variables.
  • Understanding of kinematic equations
  • Basic knowledge of initial and final velocity
  • Familiarity with acceleration concepts
  • Ability to manipulate algebraic equations
  • Study the kinematic equation (Vf)^2 - (Vi)^2 = 2ax in detail
  • Learn how to derive acceleration from distance and velocity
  • Explore alternative methods for solving motion problems, including systems of equations
  • Practice problems involving initial and final velocities with varying distances
Students studying physics, particularly those focusing on kinematics, as well as educators looking for problem-solving strategies in motion analysis.
highcontrast
A motorcycle has an initial velocity of 8m/s, it increases it's speed to 17m/s, covering a distance of 30m in that time.
What is it's acceleration? How long will it take to acclerate to 17m/s?
As stated in the equation
I faced this question on a quiz tonight and had not the slighest clue as to where to begin. I tried to gather a time for the change in speed over the distance, 17 - 8, / 30, which gave an answer of .3 seconds. I then tried plugging it into d = acceleration + 1/2 a t^2, to check if it was correct, but it wasnt. The value obtained was far too small.
This question really stumped me. In all the problems I have done before a time value was given. So, I had no idea how to approach it.
Thanks for your help
To find the acceleration here, you need to first use a kinematic equation that is independent of time, since you are not given one initially. If you use (Vf)^2-(Vi)^2=2ax, where x is the distance traveled, then you can solve for acceleration and then get the time.
You should get a small acceleration by the way. Remember to convert minutes into seconds.
Are there any other ways of solving the problem?
I'm just curious because we covered the acceleration chapter in the book, and it did not mention anything. It is just a matter of simple deriving it from the equation d=acceleration + 1/2 a t^2?
The equation you posted is one of the kinematic equations. You use them by looking at what information is given in the problem, and then compare and match with the kinematic equations to see which one will solve for your unknown.
The one you posted has distance as a function of time. The problem you have does not give you time, so this equation would not be the best to use when all you want to find is the acceleration.
Yes, there are many other ways to do the problem, but using the kinematic equation that w3390 posted is by far the easiest way to go.
The other ways include solving for time as I think you are suggesting, but to do so you'd probably need a system of two equations and perhaps make a substitution with one of those to solve for time.
I plugged in the numbers, and it works! Definitely feels good to get the answer right. I do feel cheated though, because I never did learn this equation, but was tested on it.
  • · Replies 17 ·
30K
