How Big Must N Be for Stirling's Formula to Achieve 2% Accuracy?
  • Thread starter Thread starter Physgeek64
    Accuracy Formula
The discussion centers on determining the minimum value of N for which Stirling's formula achieves an accuracy of 2% when estimating N!. The key equation presented is \(\frac{N \ln N - N}{\ln N!} = \alpha\) with \(\alpha = 0.98\). It is established that the simplest version of Stirling's formula, \(N! \sim \sqrt{2 \pi} \, N^{N + (1/2)} \, e^{-N}\), must include specific factors to achieve the desired accuracy. The inequalities derived from Feller's probability book provide a framework for calculating the threshold for N.
  • Understanding of Stirling's formula and its applications in approximating factorials.
  • Familiarity with logarithmic functions and their properties, particularly \(\ln N!\).
  • Basic knowledge of inequalities and their implications in mathematical proofs.
  • Proficiency in numerical methods for evaluating functions and approximations.
  • Study the derivation and applications of Stirling's formula in greater detail.
  • Learn about numerical methods for evaluating factorials and logarithmic functions.
  • Explore Feller's probability book, particularly pages 52-54, for insights on Stirling's approximation.
  • Investigate the implications of additive constants in logarithmic approximations and their effects on accuracy.
Mathematicians, statisticians, and students studying probability theory or numerical analysis, particularly those interested in approximating factorials and understanding the limits of Stirling's formula.
Physgeek64
How big must N be for the simple version of stirlings formula to be accurate to within 2%
So I think the starting point is
##\frac{N lnN-N}{lnN!} =\alpha ## where ##\alpha=0.98##
But i have no idea how to solve this expression for N
Many thanks
You can't solve it algebraically, but you can substitute values of N. With N = 100, ##\alpha \approx 0.991##
One thing that can aid in the computation is ## \ln{ N!}=\ln{N}+\ln(N-1)+... +\ln{2}+\ln{1} ##, but otherwise, this simply needs to be computed with the computer doing the work.
Many thanks
What, exactly, do you regard as the "simple version" of Stirling's formula? The simplest version that actually works is
$$N! \sim \sqrt{2 \pi} \, N^{N+ (1/2)} \, e^{-N},$$
and without the factors ##\sqrt{2 \pi}## and ##\sqrt{N}## the formula can never, ever get within 2% of ##N!##, no matter how large is ##N##.
However, in pp. 52--54 of his beautiful probability book, Feller gives a surprisingly simple derivation of the following:
$$\sqrt{2 \pi} N^{N+ (1/2)} e^{-N} < N! < \sqrt{2 \pi} \, N^{N+ (1/2)} \, e^{-N\:+\: 1/(12N)},$$
and this works for all ##N \geq 1##. (For clarity:the exponent is ##-N + \frac{1}{12N}##.) For example, even when ##N## is as small as ##N=1## the inequalities read as ##0.9221< 1 < 1.002##.
The inequalities should allow you to figure out when ##\sqrt{2 \pi}\, N^{N+ (1/2)} \, e^{-N}## comes within 2% of ##N!##.
See, eg., https://www.amazon.com/dp/0471257087/?tag=pfamazon01-20 for more information on Feller's book. I understand that free versions are now available on-line as pdf files.
I think the 'simplest formula' is meant to be ##NlnN-N## in this case
It is simple for sure; it is also wrong. You must beware of assuming that an accurate formula for ##\ln (f(n)## produces an accurate formula for ##f(n)## via exponentiation. It generally does not, and Stirling's formula is a perfect example of that.
Okay, but how would i go about working out for which N gives an answer to within 2% of the true value? Thanks :)
Use the two inequalities I wrote in #4.
Can you solve for N in these, or just plug in values of N?
If the accuracy of ln( f(n) ) is in terms of abs( trueValue - estimatedValue ) and the desired accuracy is in terms of percentage, I think this should be possible.
Unfortunately, not. If ##f(n) \sim g(n) \to \infty## as well as ## \ln f(n), \ln g(n) \to \infty##, then we have ##\ln f(n) \sim \ln g(n)##. However, we also have ##\ln f(n) \sim \ln 2 + \ln g(n)##, and yet we do not have ##2 g(n)## asymptotic to ##f(n)##. And that is the problem right there: an additive constant in the logarithm (whose importance goes to zero in the limit) becomes a constant mutliplicative factor in the original function, whose importance never goes away.
You can do it either way, but solving directly for N is easier.
  • · Replies 19 ·
