Acid-Base Titration: Solve Question w/ Phenolphthalein & Methyl Orange
  • Thread starter Thread starter Clari
    Titration
The forum discussion centers on an acid-base titration involving a 25 cm³ solution of 0.5M sodium carbonate and 0.5M sodium hydrogencarbonate titrated with 1M HCl. The first endpoint is reached after adding 12.5 cm³ of HCl, where phenolphthalein indicator is used. To reach the second endpoint, an additional 25 cm³ of HCl is required, totaling 37.5 cm³ for the complete titration, which changes the color of methyl orange from yellow to orange. The confusion arises from the interpretation of the total volume of HCl needed for the titration.
  • Understanding of acid-base titration principles
  • Knowledge of indicators, specifically phenolphthalein and methyl orange
  • Familiarity with molarity calculations
  • Basic chemical reaction equations involving acids and bases
  • Study the chemical reactions involved in acid-base titrations
  • Learn about the pH range and color change of methyl orange
  • Explore the concept of titration curves and their significance
  • Investigate the role of different indicators in titrations
Chemistry students, educators, and laboratory technicians involved in titration experiments and acid-base chemistry.
Clari
Hello! Here is a acid-base titration question which I am a bit confused at, please help me with it.
If 25cm^3 solution containing 0.5M sodium carbonate and 0.5M sodium hydrogencarbonate is titrated with 1M HCl using phenolphthalein indicator. Upon the addition of 12.5cm^3 HCl, the phenolphthalein is decolourized. After the 1st end point, methyl orange indicator is added and the solution is further titrated with HCl. What is the volume of HCl needed the change the colour of methyl orange from yellow to orange?
My teacher told me it was 37.5 cm^3, but I don't understand it. I think it is 25 cm^3...
Chemistry news on Phys.org
Write down reaction that takes place before first endpoint.
How much HCl do you need to reach first endpoint?
Write down reaction that takes place before second endpoint.
How much HCl do you need to reach second endpoint?
Calculate total amount of HCl needed.
Try these questions and - if you will be still not able to find out why it is 37.5 cc - post your answers so that we will be able to show you where you have gone wrong.
Unless someone decide to show you results of calculations before checking out if you are not able to do it by yourself :(
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
God I swear why do they still do A-B titrations in school. They are totally worthless, not one chemist in the real world does A-B titrations like they are taught to undergraduates.
Hello Borek, Thank you for your help. however, I am still not able to understand why it is 37.5 cc. Here are my steps:
The reaction that happens to reach the first end point is:
sodium carbonate + HCl --> sodium hydrogencarbonate + NaCl
Since there are 0.025*0.5= 0.0125 mol of sodium carbonate, 0.0125 mol of HCl is needed. That is, 12.5 cc of HCl is needed to reach the first end point.
The reaction that happens to reach the second end point it:
sodium hydrogencarbonate + HCl --> NaCl + water + carbon dioxide
Since there are 0.0125 mol sodium hydrogencarbonate originally,adds up with the 0.0125 mol of sodium hydrogencarbonate formed before the first end point, there will be totally 0.025 mol of sodium hydrogencarbonate. Therefore, 0.025 mol, and thus, 25 cc of HCl is needed to reach the second end point.
Therefore the total amount of HCl added is 37.5 cc.
But, in my notes, it says " Upon the addition of 37.5 cc of HCl, the methyl orange changes from yellow to orange". I don't think it is right, because that just means 50 cc of HCl is needed in total...or I have mistaken something? please tell me.
Just as a question what does methyl orange actually indicate exactly? Like when does it actually change color?
It looks like you might be right... though, maybe your teacher had mistaken the total HCl added instead...
It is not 'upon addition of 37.5 cc more'!
Titration goes as follows:
0 cc titrant added - phenolophtaleine visible
12.5 cc titrant added - phenolophtaleine color disappears
now you add methyl orange and the solution is yellow
total of 37.5 cc titrant added - solution changes to orange
So you have to add either 25 cc of titrant to the solution that have reached first end-point, or total of 37.5 cc of titrant to the not yet titrated solution.
Sorry if my explanation is not readable or wrong - I did my best :blushing: but English is my second language and perhaps I have missed something.
apchemstudent said:
Just as a question what does methyl orange actually indicate exactly? Like when does it actually change color?...
I think it is about 4.0 that makes the methyl orange to change from yellow to orange.
It is not 25 cc of the titrant added which makes the solution to reach the first end point...it should be the second end point.. :wink:
22K
20K
