Acoustics & Physics: Is Frequency Linked to Wave Width?
The discussion confirms that higher frequency sound waves correspond to narrower wavelengths, as established by Huygens Principle. Participants clarify that while sound waves do not have a fixed 'size', the 'tightness' of a sound beam is influenced by diffraction and the aperture of the source. The size of a needle hydrophone is related to its ability to detect ultrasound waves, which are narrower in wavelength when compared to sound in air. The conversation emphasizes the importance of questioning and seeking clarity from educators when concepts are misunderstood.
  • Understanding of Huygens Principle
  • Knowledge of sound wave propagation in different mediums
  • Familiarity with diffraction and its effects on wave behavior
  • Basic principles of hydrophone design and function
  • Research the relationship between frequency and wavelength in acoustics
  • Study the principles of diffraction and its impact on sound wave directionality
  • Explore the design and applications of needle hydrophones in underwater acoustics
  • Investigate the differences in sound wave behavior in air versus water
Acoustics researchers, underwater engineers, students in physics or biology, and anyone involved in the design and application of hydrophones for measuring ultrasound waves.
F2fHaziq Zaini 93
Is it true that the higher the frequency of sound, the narrower the wave will be?
Welcome to the PF. :smile:
The simple answer to your question is Yes. Have a look at this information page to see if it helps your understanding. Post here in your thread if you have questions about the link.
https://en.wikipedia.org/wiki/Wavelength
Thanks Berkeman for the reply. Although I wasnt talking abt the wavelength. More like the size of the sound wave.
You see I am trying to understand the use of a needle hydrophone which is used to detect ultrasound waves underwater. So I am basically trying to find out why it's so small in size. I have heard from my professors that sound waves become narrower, as the frequency increases(Huygens Principle)
A wave can't be assigned a 'size'. It can propagate any distance and all waves spread out from the nominal direction they are pointed in. The only spatial quantity is wavelength.
However, you may be referring to the 'tightness' of a beam that can be produced. That is limited by Diffraction and depends mostly on the 'aperture' or width of the source (projector or radio antenna etc). You need a wide source to produce a narrow beam.
Your needle hydrophone is small and will not be very directional. Your professor was probably talking loosely about wavelength which, for sound in water, is a lot greater than it is in air because the wave speed is so much higher.
But, when teachers tell you something that doesn't make sense to you, you should challenge them and ask for clarity. Asking about this particular confusion is fully justified.
PS Your professor is, presumably, a Biologist and not a Physicist, which could explain the problem. :wink:
I think I believed him because of the fact that when you look at the size of hydrophones; the higher the frequency, the smaller the size of the hydrophone.Which led me to think that sound at the Mhz range will be pretty small. I actually tried explaining to him that it's probably bcuz of the wavelength.
What should I be reading? So that I can understand why a hydrophone has to be needle-shaped?
Appreciate the help :)
(FYI: I am doing a project that involves measuring the power of ultrasound waves in water)
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 42 ·
