Action in Lagrangian Mechanics
Dario56
Lagrangian mechanics is built upon calculus of variation. This means that we want to find out function which is a stationary point of particular function (functional) which in Lagrangian mechanics is called the action.
To know what this function is, action needs to be defined first. Action is defined via integral.
In problems which use calculus of variation such as brachistochrone problem, caternary problem or finding path of least distance between two points, appropriate integral is the integral between two points of question of appropriate variable (time, potential energy, distance etc.), that is the integral of variable which is usually needed to be minimized in the problem (can be maximized as well).
When integral is defined, function is known and with Euler - Lagrange equation we get the solution to the problem. For example that can be function which defines path of least time, distance or shape of the rope as a solution of caternary problem.
What I don't understand is how to define this integral in context of Lagrangian mechanics or in context of action? In another words, how did Lagrange found out that difference in kinetic and potential energy of the system (commonly known as Lagrangian) gives correct equations of motion when plugged in Euler - Lagrange equation?
Wikipedia has a page on the history and development of the principle of least action:
https://en.wikipedia.org/wiki/Stationary-action_principle
Probably similar to this
You might try looking at Lanczos
https://www.amazon.com/dp/0486650677/?tag=pfamazon01-20
Rojo and Bloch
https://www.amazon.com/dp/0521869021/?tag=pfamazon01-20
Coopersmith
https://www.amazon.com/dp/0198743041/?tag=pfamazon01-20
  • Haha
You don't need lagrange, you need Newton+hamilton+idea of test particle. We, as physicists, use test particles to learn about the behavior and motion about the world around us.
Newton's first law is basically "test particles, when left alone, will move in a straight line at a constant speed".
Then a guy called Hamilton sets up a premise called "principle of least action" which uses Newton's ideal+geometry, in which you must notice that a straight line between two points can be thought of as "the shortest distance" or "least time" between two points. If you agree with this, then bam, you formulate the following integral formulation:
$$S =-mc \int^{\tau_{final}}_{\tau_{initial}} d \tau$$
Minimizing this for some $\tau$ will give you the trajectory of a free particle. There is more to this story, and I hand waved a little, but I believe your question isn't really with lagrange, but more so with hamilton, Newton, and the ideal of a test particle, and at the core, what IS a principle of least action?!
Now, I've never TRULY gotten classical mechanics because it never sat right with me, but if the above is what you're questioning, I'm sure Feynman can do a better (and more through) job than I can, and you can find more information here:
https://www.feynmanlectures.caltech.edu/II_19.html
