Can Angles Be Assigned Dimension in Scientific Calculations?
  • Thread starter Thread starter HappyFeynman
    Units
Angles can be assigned dimensions in scientific calculations, but care must be taken when combining terms with different powers of radians. While rad^2 is dimensionless, mixing radians in even and odd powers can indicate an error in calculations. For instance, energy and angular momentum cannot be equated due to their differing dimensions. The discussion emphasizes the importance of maintaining dimensional consistency in physics equations. Understanding these principles is crucial for accurate scientific analysis.
HappyFeynman
In class, we had determined that radians are a form of a count of distance in terms of radius units. We stated this is different from other units such as m, s, etc. I am having an issue in determining whether two values can be added. Lets say we have the equation (6.7 rad^2 * m) + (3 m) = z. Since we defined radians as a count of distance, we can put it in terms such as 1 rad^2 = m^2 / m^2 = 1, so it is dimensionless. Because of this, can I add the two values to simply state that z= 9.7 m?
1 rad^2 = m^2 / m^2 =1
(6.7 rad^2 * m) + (3 m) = 9.7 m
You might find this interesting: https://www.physicsforums.com/insights/can-angles-assigned-dimension/.
The bottom line is that rad2 is certainly dimensionless, but if you find you are adding terms that have a mix of radians to an even power and radians to an odd power then you have very likely gone wrong. E.g. energy, ##ML^2T^{-2}##, cannot equal angular momentum, ##ML^2T^{-2}\Omega##, where ##\Omega## represents the 'angular' dimension.
Likes BvU
  • · Replies 20 ·
