Adding Vectors Using the Component Method
The discussion revolves around adding vectors using the component method, specifically focusing on vector A and vector B, where vector B has a length of 3.25 m and an angle of 28.5°. Participants are tasked with expressing the resultant vector A + B in unit-vector notation.
  • Participants discuss the calculation of components for both vectors A and B, with some uncertainty about the correct approach for vector B, which is vertical. Questions arise about the angle measurement for vector B and whether it is appropriate to assume certain component values.
Guidance has been offered regarding the addition of vector components separately, with some participants confirming the understanding of how to calculate the resultant vector. There is acknowledgment of the need to clarify assumptions about the components of vector B.
Some participants express confusion regarding the information available for vector B and whether it is valid to assume its components based on its vertical orientation. There is also mention of the importance of understanding the meaning behind the equations used for calculating vector components.
upwardfalling
Use the component method to add the vectors vector A and vector B shown in the figure. The length of vector B is 3.25 m and the angle θ = 28.5°. Express the resultant vector A + vector B in unit-vector notation.
x = rcos
y = rsin
I drew the components for vector A, and got Ax = 3cos28.5 = 2.64m and Ay = 3sin28.5 = 1.43m ( i don't know if they are correct though). I'm lost at what to do next for vector B cause its a vertical line.
Is it right for me to say that after finding vector B's components, i add the X components to find i unit vector and add the Y components to find the j unit vector? And i just get the answer by putting them in one equation, i + j?
Well, if it's perpendicular to the x-axis think of what is the angle for it's measure (if the positive x-axis is 0)?
I don't know if I'm answering your question, but is it 90 degrees..?
Yes. Good. So now you can calculate the components of the B vector. It's ok if one of them is zero.
I'm not so sure about how to calculate the components. As in isn't there not enough information?
I don't know if i can just assume Bx = 0 and By = 3.25m, but if i can, will it be Ax + Bx = 2.64 + 0 = 2.64i and Ay + By = 1.43 + 3.25 = 4.68j?
It is 90 degrees but think about what x=rcosθ and y=rsinθ actually means; don't just plug into the formulae and hope.
The vector is being split up into 2 vectors in perpendicular directions: (x,y). Here you calculated A as (2.64m,1.43m). This means, if I move 2.64 in the x direction and 1.43 in the y direction, you will end up where the vector points (i.e. 3m away at 28.5 degrees).
If my vector was (a,b) and I wanted to add (c,d) to it, this means going a in the x direction, then b in the x direction, then c in the x direction, then d in the y direction. This is clearly a+c in the x direction and b+d in the y direction. Therefore this results in (a,b)+(c,d)=(a+c,b+d).
If B is a vertical line, it only has a y component. You don't need to travel in the x direction at all to reach the end of the arrow. This means the vector will be (0,3.25). i.e. 0 in the x direction, 3.25 in the y direction. It is easier to think about this than the angle and magnitude of b.
You are therefore doing the addition A+B=(rcosθ,rsinθ)+(0,By), which I shall leave to you to calculate.
I hope this helps.
I hope this helps.
I think I understand but am a little confused at the same time. It did help me in understanding why By = 0 though! And by A+B=(rcosθ,rsinθ)+(0,By), you do mean that I add the x components and y components separately, am I correct?
Exactly. They can be added separately.
This is because if my vector was (a,b) and I wanted to go one more step in the x direction, the y value wouldn't be effected at all. my new vector would be (a+1,b)
You can also think of (a,b) as (a,0)+(0,b) if that helps. Then (a,b)+(1,0) is the same as (a,0) + (1,0) + (0,b) = (a+1,0)+(0,b) = (a+1,b)
As I said before, (a,b)+(c,d) = (a+c,b+d)
Here the x and y components are being added separately
You can also think of (a,b) as (a,0)+(0,b) if that helps. Then (a,b)+(1,0) is the same as (a,0) + (1,0) + (0,b) = (a+1,0)+(0,b) = (a+1,b)As I said before, (a,b)+(c,d) = (a+c,b+d)
Alright, I think I get it! Thank you so much. Hopefully I'll get the right answer
Cool!
If you post your final answer, I'll happily confirm if it's correct or not
I got 2.64i + 4.68j , is that correct? I added (Ax + 0, Ay + By) for that answer and wrote it in unit vectors.
Yep, you've got it :smile:
Awesome, thanks for the help! :)
  • · Replies 21 ·
