Does the temperature return to its initial value in an adiabatic cycle?
  • Thread starter Thread starter elb5313
    Adiabatic Cycle
In an adiabatic cycle involving an ideal gas, the temperature returns to its initial value upon completion of the cycle. This is due to the principle that the system's state is identical at the start and end of any thermodynamic cycle. During the cycle, energy is transferred between reservoirs, resulting in work extraction and entropy production. However, the temperature remains constant after each complete cycle, regardless of the number of cycles performed. Thus, the temperature does not increase with successive cycles in an ideal adiabatic process.
elb5313
In an adiabatic compression/expansion cycle of an ideal gas, does the temperature return to its initial value after the cycle has completed? Or does it increase as the cycles continue?
At the completion of any thermodynamic cycle, the system state is identical to the initial system state. Energy was transferred from one reservoir to another during which some work was extracted and some entropy produced.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 20 ·
  • · Replies 33 ·
