Adiabatic Temperature Change in Rising Air
  • Thread starter Thread starter Physgeek64
    Adiabatic Air
10 replies · 2K views
Physgeek64
The hydrostatic equation expresses the change in pressure dp due to a layer of
atmosphere of thickness dz as
constant volume.
##dp = −\rho g dz ##
Using this expression, show that the change in temperature with height for a parcel of air that rises adiabatically in the atmosphere can be expressed as
##-\frac{\gamma-1}{\gamma} \frac{mg}{K_B}##
So I think we're trying to find ##\frac{\partial T}{\partial z}_S ## as this seems like a reversible process
starting off with ##dU=TdS-pdV##
## \frac{\partial U}{\partial T}_z dT +\frac{\partial U}{\partial z}_T dz = TdS-pdV##
## \frac{3NK_B}{2}\frac{\partial T}{\partial z}_S +\frac{\partial U}{\partial z}_T =-p\frac{\partial V}{\partial z}_S##
The fact that i can't find ## \frac{\partial V}{\partial z}_S## makes me think I've gone wrong somewhere
Many thanks
Chestermiller said:
What is the relation between T and p for an adiabatic reversible expansion? From the ideal gas law, what is the density expressed as a function of the temperature, pressure, and molecular weight?
##TV^{\gamma -1} =constant## and ##\rho=\frac{m}{V} ## ?
Chestermiller said:
I asked for T vs P, not V., $$\rho=\frac{Pm}{RT}$$
would there not be a factor of n in there?
Chestermiller said:
In the equation I wrote, The m is the molecular weight and R is the ideal gas constant. $$\rho=\frac{nm}{V}$$
Oh of course. But i don't see how to use these. Was i on the right track?
No. Actually, you weren't on the right track. You can start by substituting ##\rho=\frac{pM}{RT}## into the equation $$dp=-\rho g dz$$. Then you substitute the relationship between p and T (in terms of ##\gamma##) for an adiabatic reversible expansion.
so I get ##dp=-\frac{pmg}{K_BT}dz= -\frac{Nmg}{V}dz##
I can't see where to go from here
Chestermiller said:
$$pT^{\frac{\gamma}{(1-\gamma)}}=C$$
Thank you, I have done it now :)
