How long do the balls take to hit the ground?
The discussion centers on a physics problem involving two balls thrown from a balcony at different velocities. One ball is thrown downward at 15.5 m/s, while the other is thrown upward at the same speed. The calculations indicate that the first ball takes 0.6 seconds to hit the ground, while the second ball takes 4.2 seconds, resulting in a time difference of 3.6 seconds. Participants debate the accuracy of using 10 m/s² for gravity instead of the more precise 9.8 m/s². The thread seeks clarification on the calculations and the underlying physics principles.
Leo34005
Velocity Physics Problem
Two students are on a balcony 23.4 m above the street. One student throws a ball, b1, vertically downward at 15.5 m/s. At the same instant, the other student throws a ball, b2, vertically upward at the same speed. The second ball just misses the balcony on the way down.
(a) What is the difference in time the balls spend in the air?
(b) What is the velocity of each ball as it strikes the ground?
velocity for b1
velocity for b2
(c) How far apart are the balls 0.480 s after they are thrown?
s = ut + 1/2at
Not to sure
I am considering g = 10 m / sec^2.
Motion of the first ball:
=>23.4 = (15.5)t + 10(t^2)/2
=>23.4 = 15.5 t + 5(t^2)
=>(t^2) + 3.1t - 4.68 = 0
=> t = (-3.1 + 5.3) / 2 = 0.6 sec
Motion of the second ball
=>23.4 = - (15.5)t + 10(t^2)/2
=>23.4 = -(15.5 t) + 5(t^2)
=>(t^2) - 3.1t - 4.68 = 0
=> t = (3.1 + 5.3) / 2 = 4.2 sec
Difference in time = 3.6 sec
Need some help here
Wouldn't your g = 9.8m/s due to gravity ? As for your first question it would be the ball going down, as you throw the ball up it is going against gravity thus making it achieve its goal much slower than the ball going down.
I think what i did was wrong, and yours too, so can anyone out there help me find the answer? At least i attempted it
  • · Replies 38 ·
