Advanced Algebra, factor and simplify
6 replies · 4K views · last reply
pooker
I am having problems understanding this. Could someone explain how to arrive at the answer for this problem . (-5/2)(x)(x+3)^(-3/2) + (5)(x+3)^(-1/2) Thank you
It says to factor and simplify. Express the answer as a fraction without negative exponents.This is where I get to (-5x/2)(1/cubed root of (x+3)^3) + 5 / (cubed root of x+3 )
edit here is more i got
-5x/2(x+3)^2) + 5/(x+3)
get common denominator times the second by x+3 then by 2
so
-5x/2(x+3)^2 + 10x + 30 / 2(x+3)^2
I assume I have to get a common denominator but I am unsure of how to do that with negative fraction exponents that are not already equal.
[tex]\frac{-5x}{2\sqrt{(x+3)^3}}+\frac{5}{\sqrt{x+3}}[/tex]
[tex]\frac{-5x}{2(x+3)\sqrt{x+3}}+\frac{5}{\sqrt{x+3}}[/tex]
[tex]\frac{-5x+5*2(x+3)}{2(x+3)\sqrt{x+3}}[/tex]
Do you feel comfortable to continue now?
let me try now
attain common denominator
so multiply other side by 2(x+3)
so we get
-5x/2(x+3)(square root x+3) + 10(x+3)/2(x+3)(square root x+3)
simplify
10x+30
since they are know common denominators do the addition
5x + 30 / 2x+6(square root x+3)
Is this correct or am I wrong ?
pooker said:
let me try now
so we get
simplify
10x+30
You're right. Also, it is even better when you rationalize (multiply the whole equation with sqrt(x+3)/sqrt(x+3)) so that you eliminate the square root in the denominator.
Regards.
thank you very much aaron you really helped me out with future problems. Our teacher said only 25% of students pass this class out of 24. Here is my next one I tried to work
((-4/x+h) + (-4/x) ) / h
I remember something called ltw, where if you had addition in the denominator you multipled each side by the others denominator.
So we would get
-4x/(x^2 + h) + 4x + h / x^2 + h
of course all divided by h
now that the top has a common denominator we simplay add the two together leaving us
h / x^2 + h the H should cancel out leaving
1/ x^2
now for the remainder the total problem is now
(1/x^2) / h we can reverse the bottom and multiply fractions so
1/(x^2) * 1/h we get 1/ (x^2H) is this correct Aaron?
btw you are really smart. :)
When you multiply the denominator x + h by x how do you end up with x^2 + h?
[tex]\frac{\frac{-4x}{x(x+h)}+\frac{-4(x+h)}{x(x+h)}}{h}[/tex]
[tex]\frac{-4x-4x-4h}{xh(x+h)}[/tex]
The final result:
[tex]-\frac{4(2x+h)}{xh(x+h)}[/tex]
