Why Does Closing My Door Increase the Breeze in My Room?
  • Context: High School
  • Thread starter Thread starter blackmarch103
    Air Air flow Flow
The discussion centers on the phenomenon of airflow in a room with a closed door, specifically in a corner-end room on the 7th floor with two windows. It is established that closing the door increases the intensity of the breeze due to the pressure differential created by the airflow through a smaller gap. As the door nears closure, the breeze intensifies, demonstrating the principles of fluid dynamics where the same volume of air must move faster through a smaller opening, resulting in a greater pressure drop and a stronger force on the door.
  • Understanding of basic fluid dynamics principles
  • Knowledge of pressure differentials in airflow
  • Familiarity with airflow measurement techniques
  • Experience with environmental factors affecting indoor air quality
  • Research the principles of Bernoulli's equation in fluid dynamics
  • Learn about airflow measurement tools such as an anemometer
  • Explore the effects of pressure differentials in HVAC systems
  • Investigate the impact of window placement on indoor airflow
Individuals interested in environmental science, HVAC professionals, and anyone seeking to optimize airflow and comfort in indoor spaces.
blackmarch103
Hi, I have a question about air flow. My room is located on the corner-end of my building, on the 7th floor. I have two windows, each one facing a different side of the building, and one of the windows typically produces the breeze, and the other never does.
When the door to my room is closed, there is typically less of a breeze. When the door is open, the breeze picks up a little. This is all fine and good, but here's where it gets interesting:
The closer the door is to being completely shut. the more the breeze intensifies. It's like the air outside is rushing through my room to get into the rest of my house before the door closes. I can feel the resistance the door exerts on me, and it gets stronger the closer the door is to being completely shut.
Whenever I feel too hot, I can summon a strong refreshing blast of wind by just pushing the door towards the doorframe till it's open just a crack. And here's the thing, if the door does shut completely, the wind stops immediately
Can someone please explain what exactly is going on?
Welcome to the PF.
Do you feel this effect only when you are standing at the door? Or if you have a friend closing the door, does the breeze felt by you at the window also intensify?
Have you measured the air flow, or do you just evaluate it by listening to the whistling? Same flow through a small opening will be much noisier (requires higher speed of air) than through a large opening, leaving you with the feeling flow changes - when it fact it can be exactly the same.
+1
Same volume of air trying to get through a smaller gap requires a faster air flow. Also causes a greater pressure drop through the door creating a force on the door.
  • · Replies 42 ·
12K
