Algebra problem on final step
  • Thread starter Thread starter Restless
    Algebra Final
8 replies · 2K views
Restless
[tex]8x^2-7a^2=19a^2-5ax[/tex]
None
[tex]13ax^2-7a^2=19a^2[/tex]
[tex]13ax^2=26a^2[/tex]
Now I'm not sure what I should do next...
Maybe divide both sides by 2 to get rid of the squares
[tex]13ax=26a[/tex]
Then say that [itex]ax = 13a[/itex] ?
I am confused.
None
[tex]13ax=26a[/tex]
I am confused.
In your attempt at a solution where did the -5ax term go?
It seems you just dropped it. Oh I see no you can't add the x^2 and x terms together to get 13ax^2.
The strategy should be to group terms so that the right hand side of the equation is a quadratic in x and the left hand side is 0.
then find the roots of the quadratic.
Is there something you're supposed to do with this, like, say, solve for x?
Restless said:
None
You have a mistake above. Apparently you added 5ax to 8x2 and got 13ax2. They are not like terms, so can't be combined.
Dividing by 2 doesn't get rid of exponents.
Restless said:
[tex]13ax=26a[/tex]
There's an error above, as well. You divided the left side by 13, but divided the right side by 2. You can't do that.
Restless said:
I am confused.
Ok so I thought about the problem again and now I have
[tex]8x^2=26a^2-5ax[/tex]
But now I don't see any like terms or anything I can reduce or eliminate
Bring it to the format
and
just use the quadratic root equation
in your case it would be [itex]8 x^2 - 26a^2 + 5ax=0[/itex]
I don't understand how to enter my equation into that formula
in you equation [tex]x=x[/tex]
[tex]a= 8[/tex]
[tex]b= +5a[/tex]
[tex]c= -26a ^ 2[/tex]
and
It would be better as 8x2 + 5ax - 26a2 = 0
Does it tell you to solve for X, it's a bit confusing, since you have left it unmentioned or I am missing something. Anywho, what you cannot do for certain is divide the sides of the equal sign with x or a. If it were x you were solving for, if you divide it like that, then one of your solutions will disappear, the number of the dimension of the variable tells you how many solutions there will have to be.
You can treat both of the numbers a and x as variables here. 1 time, solve for x and then solve again for a, since you haven't said what needs to be done. I have a hunch one needs to solve for x here.
